Tamiya F103 Forum
#1653
If you bolt 104 rims onto the 103, the front end will remain 200mm wide as the front end assembly is wider but the front wheel width is the same.
The F104 front end will bolt right onto the F103 chassis and is a common practice to acheive a 180mm width car. The rear end will reduce to 180mm due to the overall width of the rear tires.
My F104 F60 Ferrari kit uses the same rear axle configuration as the F103 so the width is the same, only the wheels/tires are different.
The rear pod from the 104 as mentioned a couple posts back will allow you to get a lower ride height as the axle sits higher in the sideframe.
#1654
Thanks for your comments. Yes this is Jean Alesi Ferrari 412 V12 (the last Ferrari V12).
I did this car to commemorate his only F1 victory in the Canedian GP where at "Schumi" gave him a lift on the air intake of his F1 to the podium, for Alesi had run out of gas in his celebration lap.
Body: Tamiya C body set.
Decals: D Drive / F1 90's set.
Cheers!
#1655
UF1 Series
UF1 Winter Series
2nd Race will be this Saturday...
Doors open at 10AM....
Qualifying at 12...
http://uf1series.com/
Qualifying at 12...
#1657
#1658
How is the 3 racing shock? I can't find the TRF shock and the shock with the kit doesn't look to good.
#1660
#1661
hey guys don't want to Hijack the thread, but we are busy building up the F1 Class up here in the NW and at Timezone II. we have started bringing in tires and such, but kind of messed up on some of the type we need. we have quite a few Ride Grooved Tires for the F103 and free shipping through Christmas
http://www.timezonehobbies.com/store...0ab976d096ff75
24000
24001
24003
Looking forward to growing F1 up here and trying to get an F1 only race on our schedule....
24000
24001
24003
#1662
I think this is the shock James is talking about.
http://www.rcmart.com/rc-f103gt-yeah...s-p-28803.html
#1663
UF1 Series
3rd round of the UF1 Winter Series this Saturday in Chino California...
Qualifying begins at 12 noon...
Hideo Kitazawa is flying over from Japan to join us... Hard core baby !
http://uf1series.com/index.html
http://uf1series.com/_gallery/UF1Girls1.html
#1664
Hy there!
First of all, a merry Christmas to all from Austria!
I have a question regarding the ZEN Foam tires
There are Front 35 and 30, and Rear 35, 30, and 25 shore available.
Aditional there are also these two available: Front HI Rubber Tires, and Rear HI Rubber Tires.
Can anybody explain wich shore they have or for wich conditions wich shores are usefull?
Greetings Rainer
Greetings Rainer
#1665
Mr Lightfoot if you can get the girl at the top to come to the race i'll fly over from the UK..
