Like Tree1Likes
Old 05-21-2011, 06:37 PM   #1576
I've got a slight problem. I have a F103 and I just installed the 3 racing rear alum pod. I also have the alum ride height adjusters. Problem I want to run an Associated axle like I had it it before with bearing adaptor. Any idea if there is a bearing adaptor for 3racing to be able to for an Assoicated axle.
Team Epic/Trinity -Michael Bruce Hobbies-Team CRC ,Kimbrough Products and GForce.
WGT-R, GT Racing USA (17.5 foam), Formula 1 and Home Track is 386 RaceWay,ROAR #7540.
BullFrog is offline   Reply With Quote
Old 05-21-2011, 06:45 PM   #1577
abailey21's Avatar
Trader Rating: 36 (100%+)
the 12L axle fits the 3 racing rear end. I ran the same setup in my 104
K.C.C.O.
abailey21 is offline   Reply With Quote
Old 05-22-2011, 12:59 AM   #1578
Originally Posted by bakaguyjean View Post
Are you using the trailing arm up rights? They are designed to take away steering. I guess you are using these as you said your axles are getting loose.throw on the stock pieces and uses those if you are not using them now and you will get your steering back.
For the vibration use shims on your axles,or get rid of theTamiya wheels. That sound you hear when you corner is "The Tamiya sound" this goes away with good wheels.
i am running standard uprights hence why i was surprised with the amount of understeer.i also have small shims in the axles but didnt realise the tamiya wheels were prone to chatter. would the zen wheels work any better? thay seem to be the only 103 foam wheels i can find(non tamiya)
freakyfreakyflo is offline   Reply With Quote
Old 05-22-2011, 07:20 AM   #1579
Are you using the flanged ball bearing in the alum. adjusters. Because that's what I've got and they don't fit because of the flange.Do the flangeless bearing work?I found some flangeless BB and they don't work either.The size of the hole for the bb is 9.6mm. maybe they changed since you got yours?the part number for the adjusters is F103rm-03.
Old 05-22-2011, 11:32 PM   #1580
i am talking about the front axles,not the rear
Old 05-23-2011, 06:06 AM   #1581
I was referring to ABailey.
Old 05-24-2011, 12:51 PM   #1582
Could someone please post the Tamiya Part Number and Firmness of the Tamiya Foam F103 Tires?
Number 49 Lou's Speedway Canada, Honda House www.hondahouse.com
ElliotCanada is offline   Reply With Quote
Old 05-28-2011, 05:26 PM   #1583
HeliYogi's Avatar
Trader Rating: 16 (100%+)
Default For the first time :)
Bring them out boys
More F-1 RC action? RCTECH Formula-1-RC-Northwest & FB @WhatBrakes
HeliYogi is offline   Reply With Quote
Old 05-30-2011, 03:52 AM   #1584
Hey guys,
i recently got my f103 and am having issues mounting the esc and receiver and then putting the body on top... how have you guys managed to work around this? when i put my shell on it leands to one side not matter what i do.
Pok.
pokiou is offline   Reply With Quote
Old 06-02-2011, 09:29 AM   #1585
lightfoot's Avatar
Default Uf1 Series
This Sunday Circuit of the Americas ( Surf City )
4th race of the UF1 Series...
For more info....
http://uf1series.com/schedule.html
Love and Peace...
lightfoot is offline   Reply With Quote
Old 06-03-2011, 04:14 AM   #1586
UrabusDenis's Avatar
Hello guys !
I'm very interested in buying this second-hand F103 . The owner sasy it's 8 years old and very rarely used . It has a carbon chassis but everything else is standard plastic . I will run it rarely on an outisde asphalt track , since there is no F1 competition here . What do you think , is it worth buying ?
UrabusDenis is offline   Reply With Quote
Old 06-03-2011, 04:22 AM   #1587
kneedeeppow's Avatar
depends on how much you are paying for it it looks like its in pretty good nick as per photo.103 is a nice rcf1 car,great to drive
https://www.facebook.com/Fresh10drift/
Eagle Racing GRT FRD. Tamiya F103GT. Tamiya Blackfoot............ORIGINAL
kneedeeppow is offline   Reply With Quote
Old 06-03-2011, 04:28 AM   #1588
abailey21's Avatar
It looks good, but that appears to be the FRP chassis, and not the carbon.
Plus they are only 120.00 brand new...
http://www.rcmart.com/catalog/rc-tam...a-p-33343.html
K.C.C.O.
Old 06-03-2011, 04:37 AM   #1589
Well , converted into dollars it's about 50$ . It comes with a servo , silver can and a battery . It doesn't come with a body however . I think it's a good deal ...
I'm experienced in TC and 1/18 but I know very little about F1 However , I always found it very interesting . Hopefully I'll make this deal ...
Old 06-03-2011, 05:14 AM   #1590
abailey21's Avatar
not a bad deal at all for 50 bucks
K.C.C.O.
FS: Tamiya F103 mild seven Australia For Sale/Trade 4 08-19-2008 11:19 PM
Tamiya F103 GT izzyracer R/C Items: For Sale/Trade 2 03-01-2007 03:51 PM
Tamiya F103 NIB Jspecrcr R/C Items: For Sale/Trade 7 11-07-2006 01:30 PM
WTB: Tamiya buggy & Tamiya f103 stuff rays_tt Australia Wanted to Buy 2 04-20-2006 06:10 AM
Tamiya F103 or F103 Parts MM-F1 R/C Items: Wanted to Buy 4 04-24-2004 03:14 PM
