Old 05-11-2011, 02:21 AM   #1561
Default 103 rubber wheels?
hey guys
i am shopping for some rubber feet for my 103 but am unsure what wheels to mount them on. i like the look of the shimizu 103 tires. what wheels are suitable for these tires?
freakyfreakyflo is offline   Reply With Quote
Old 05-11-2011, 04:17 AM   #1562
oldnwise's Avatar
Originally Posted by freakyfreakyflo View Post
hey guys
TRG and CROSS rims are the best quality for rubber. TRG2203 for the rear and TRG2105 for the front are the most readily available. CROSS rims for the F103 are harder to find.
RIDE also make rims for rubber but quality is poor and a waste of money.
oldnwise is offline   Reply With Quote
Old 05-12-2011, 03:06 AM   #1563
hey guys
you can use shimizu tires, which are designed to be mounted on any foam wheel
prorace is offline   Reply With Quote
Old 05-12-2011, 10:13 AM   #1564
MikeR's Avatar
Trader Rating: 14 (100%+)
Hi All,
The new bolt on servo mounts are now in stock for the F103/exo103! Gives you on the fly ackerman changes when using low profile servos
http://www41.instantestore.net/merch...-mount-set.cfm
www.exotekracing.com ☆ASSOCIATED☆DURANGO☆HPI☆HB RACING☆KYOSHO☆LOSI/TLR☆SERPENT☆TAMIYA☆XRAY☆
A picture with your post, when trouble shooting, will probably get more rctech help than without...
MikeR is offline   Reply With Quote
Old 05-12-2011, 06:31 PM   #1565
lightfoot's Avatar
Default Uf1 Series
This Saturday at Tamiya Track ( 2 Orion Aliso Viejo, CA 92656 )
UF1 Series continues with race #3
gates open at 8AM
Qualifying around noon
3 rounds of racing starts at 2PM
Control practice in the morning....
power will be supplied...
for more info :
http://charleslightfoot.com/UF1/rules.html
Love and Peace...
lightfoot is offline   Reply With Quote
Old 05-13-2011, 08:16 PM   #1566
Looking for another part that is temporary sold out at Tamiya - For the F103 the Gear Case set #51243. Anyone know if someone has one available?
Team Epic/Trinity -Michael Bruce Hobbies-Team CRC ,Kimbrough Products and GForce.
WGT-R, GT Racing USA (17.5 foam), Formula 1 and Home Track is 386 RaceWay.
BullFrog is offline   Reply With Quote
Old 05-14-2011, 12:20 AM   #1567
Pro10noob's Avatar
Check link http://shop.ebay.nl/i.html?LH_AvailT...w=Tamiya+51243
regards Roy
l===/o\===l
[_]-###-[_] V-link proto type Pro10,JKMR P235-SE Pro10
P235-VL Pro10 comming soon
Sponsered by me,myself and i :)
Pro10noob is offline   Reply With Quote
Old 05-14-2011, 05:59 AM   #1568
j.d.roost's Avatar
Trader Rating: 27 (100%+)
Originally Posted by MikeR View Post
Hi All,
THANK YOU!
It's about time that we got a decent servo holder.
F1
Roche usa
R.I.P. Jon Williams
j.d.roost is offline   Reply With Quote
Old 05-14-2011, 12:27 PM   #1569
I need someone in the USA- thanks.
Old 05-20-2011, 02:17 PM   #1570
spring71's Avatar
Smile
F103 Bodies are arrived at TQ
Click Here to check out.
Thanks.
TQ RC RACING
Indoor RC Race Track & Hobby Shop in Chino, CA
Online Shop
http://www.tqrcracing.com
tq@tqrcracing.com
spring71 is offline   Reply With Quote
Old 05-20-2011, 03:35 PM   #1571
Pro10noob's Avatar
I got that Ligier brand new in box
Original Tamiya with decals.
regards Roy
Thanks.
l===/o\===l
Old 05-20-2011, 04:42 PM   #1572
GasGod's Avatar
Originally Posted by j.d.roost View Post
THANK YOU!
JD I thought I showed you the grub screw trick--
can I now join the B.B.T.?
F! Metal Militia,VTA NATION--Team SloMoFo
losi 8t,mbx5t,rc8
rc8,Kyosho rb5,SCR
ft4 MT wallet
cyclone;xxx-s;x-rayT2;crc gen xl;bmi 12rrl
GasGod is offline   Reply With Quote
Old 05-21-2011, 02:07 AM   #1573
i find my f1 understeers alot on foams. it vibrates so much it rattles the front axles loose.it currently has 35 on the fronts and 25s on the rear. anyone out there with some tips for a f1 noob?
Old 05-21-2011, 02:40 AM   #1574
Pro10noob's Avatar
What wheels are you running?
If they are the Tamiya foams wheel i can understand you got vibrations.
If you run aftermarket wheel, it depends on what brand they are.
I got blade wheels and the one i have run true and after mounting the foams and trueing them i got hardly any or none vibrations
If you have the Tamiya rubber wheels and cut the inside rim that holds the rubber tire from moving in and mount foam on them,then you got yourself also a nice set after trueing.
regards Roy
l===/o\===l
Old 05-21-2011, 02:55 AM   #1575
bakaguyjean's Avatar
Are you using the trailing arm up rights? They are designed to take away steering. I guess you are using these as you said your axles are getting loose.throw on the stock pieces and uses those if you are not using them now and you will get your steering back.
For the vibration use shims on your axles,or get rid of theTamiya wheels. That sound you hear when you corner is "The Tamiya sound" this goes away with good wheels.
bakaguyjean is offline   Reply With Quote
FS: Tamiya F103 mild seven Australia For Sale/Trade 4 08-20-2008 12:19 AM
Tamiya F103 GT izzyracer R/C Items: For Sale/Trade 2 03-01-2007 04:51 PM
Tamiya F103 NIB Jspecrcr R/C Items: For Sale/Trade 7 11-07-2006 02:30 PM
WTB: Tamiya buggy & Tamiya f103 stuff rays_tt Australia Wanted to Buy 2 04-20-2006 07:10 AM
Tamiya F103 or F103 Parts MM-F1 R/C Items: Wanted to Buy 4 04-24-2004 04:14 PM
SEO by vBSEO 3.5.0
