Tamiya F103 Forum >
Tamiya F103 Forum
Like Tree9Likes
Tamiya F103 Forum
Old 04-29-2011, 10:26 AM
  #1546
RedBullFiXX's Avatar
Trader Rating: 34 (100%+)
Originally Posted by BullFrog
Thanks I've found everything but the fiberglass Tee- bar for the F103.Without that everything is useless. About body have a part number ?
Tamiya USA also stocks parts.
http://www.tamiyausa.com/product/ite...oduct-id=50505
http://www.tamiyausa.com/product/rcp...s&kit_id=84191
RedBullFiXX is offline
Old 04-29-2011, 10:32 AM
  #1547
Thank You I spent several hours last night looking to find just a part number.
BullFrog is offline
Old 04-29-2011, 10:46 PM
  #1548
kneedeeppow's Avatar
has anyone had any experience with Zac Project/Kawahara foams for f103?
http://d-drivesportsenglish.com/inde...roducts_id=430
kneedeeppow is offline
Old 04-29-2011, 11:13 PM
  #1549
Never tried them. I use Kevin Frewers donuts, they're cheap and good.
JR007 is offline
Old 04-29-2011, 11:55 PM
  #1550
i would to but he hasnt answered emails so looking at other options
Old 04-30-2011, 05:57 AM
  #1551
j.d.roost's Avatar
Trader Rating: 32 (100%+)
Not sure how his international shipping is,but his service here in the states is top notch.
Donuts wear nice and work good both on carpet and outdoors.
http://www.rc4less.com/index.php?cPa...6e07e316e6be32
j.d.roost is offline
Old 05-05-2011, 10:27 PM
  #1552
hi, it's been a while since I dusted out my F103. Currently I've go O-rings instead of springs at the bottom front arm. Does anyone still use this set up or everyone reverted to springs? I also read something about spring on top setup but not sure how that is implemented. Would there not be too little room between the wheel and top swing arm? Oh, I've got the swinging top arm not the fixed type if that makes a difference. Thanks.
one-nil is offline
Old 05-06-2011, 01:46 PM
  #1553
robk's Avatar
Trader Rating: 22 (100%+)
The spring on top only works with the fixed front end. The link type front end needs the spring on the bottom.
robk is offline
Old 05-06-2011, 04:32 PM
  #1554
GasGod's Avatar
Hmmmm- never heard of using o rings instead of springs ;interesting wouldn't that make the front push?
GasGod is offline
Old 05-09-2011, 08:37 AM
  #1555
Does any one know the size of the ball bearing in the F103, all bearing.
Thank you.
gofasteddy is offline
Old 05-09-2011, 09:38 AM
  #1556
Pro10noob's Avatar
Front wheel bearings are the 850 times 4 type bearings.
Rear axle depends on what motorpod you are running
Stock motorpod are 1260 times 2 and the hight adjusable gearcase are 1060 times 2
Diff bearings are 1280 times 3
You can look it up in the manuals on the Tamiya site.
regards Roy
Thank you.
Pro10noob is offline
Old 05-09-2011, 11:50 AM
  #1557
regards Roy
Thanks, but I need the actual size not the item number I have that, the manual don't give you the actual size.
Old 05-09-2011, 12:07 PM
  #1558
Pro10noob's Avatar
Those are the sizes.
850 means 8 outside,5 inside.
1060 is 10 outside 6 inside and so on
If you go to your LHS and ask for those bearings you get the right one.
regards Roy
Old 05-10-2011, 05:47 AM
  #1559
regards Roy
Ok thank you.
Old 05-10-2011, 09:28 AM
  #1560
thank you for clarifying that.
honestly, I cannot remember how it handled since it was such a long time ago. I first learnt of it from this forum when some driver won a big F103 event (apologies to said driver for not remembering your name and the event ) and then everyone found out that he was using this o-ring mod instead of the usual springs. I believe some cried foul play but was apparently OK'd by the organizers.
Last edited by one-nil; 05-10-2011 at 09:31 AM. Reason: spell check to ward off the grammar nazis
one-nil is offline
