Tamiya F103 Forum >
Tamiya F103 Forum
Like Tree9Likes
Tamiya F103 Forum
Old 09-17-2001, 09:52 PM
  #136
psycho's Avatar
Dragon Slayer
Are you using 1/10 scale Assoc. parts or 1/12 scale? I was thinking about doing the same thing. Seems like 1/10 scale has more choices of compounds.
psycho is offline
Old 09-17-2001, 10:06 PM
  #137
Dragon Slayer's Avatar
1/10 scale...i know they are not "scale" as are the Tamiya tyres, but they are alot less expensive and yes, many more compounds.On my homemade pods, the only thing i dont have is the ability of ride height adjustment,.I used 3/16" alum. i "aquired" from work and spent a heck of alot of time on these things"whew".But they look sweet.
Dragon Slayer is offline
Old 09-18-2001, 09:30 AM
  #138
psycho's Avatar
Dragon Slayer
Hmmm... I remember reading that the Assoc. axle will fit in Tamiya's rear pod. Maybe I'll experiment this off season. Thanks for the info.
psycho is offline
Old 09-18-2001, 03:13 PM
  #139
TFR
TFR's Avatar
Dragon Slayer...got any picture?
TFR is offline
Old 09-18-2001, 07:37 PM
  #140
Psycho.....i dont believe the Assoc. axle will fit. Assoc axle is 1/4 inch and the Tamiya bearing is metric....i could be wrong????
TFR....sorry , no pics...are you wanting to see the pod????
Has the Tamiya nats happened already...if not, anybody going?????Good luck.
Anybody know Russel Johnson???he went to Japan, i believe 2 years ago for the F-1 class. I raced against him several times in Dallas and Oklahoma, he was always freakin' fast. I think hes still racing.If you have his ear, get him on here.
Old 09-19-2001, 11:17 AM
  #141
rc-zombies's Avatar
Originally posted by psycho
Dragon Slayer
AE axle will not fit the Tamiya rear pod. AE is 1/4in. english. Tamiya is metric. The Tamiya rear axle is larger than AE's axle. Hower you can put Tamiya axle into a AE rear pod. I've tried it does work... all you have to do is drill out the rear axle spacers to fit the Tamiya bearing. you'll need a 10mm reammer.
rc-zombies is offline
Old 09-19-2001, 04:22 PM
  #142
psycho's Avatar
spooky
Did you guys get the Cross cars in yet? If so, how much? Do they still use those funky rear wheels?
psycho is offline
Old 09-19-2001, 04:37 PM
  #143
rc-zombies's Avatar
spooky
I have 3 Cross F1's . got them last year before Cross lost it's distributor. Schumacher's first Cross shipment in is about 4 weeks. I was able to get mine for $120.00 do not know how much they'll be going for now. What funky rear wheels...? The stock wheels and tires work very well.
Old 09-19-2001, 04:55 PM
  #144
TimPotter's Avatar
Trader Rating: 15 (100%+)
Psycho....
I will let you know when I get it...
Les has a couple of them on order.. I did not even ask how much. I 'll ask him and post it....
TimPotter is offline
Old 09-19-2001, 07:45 PM
  #145
TFR
TFR's Avatar
Oh ya, just to let you guys know....
my TCS Leman race is coming up...what sort of set up do you guys run for outdoor tracks?
for my F103RS....
psycho, you might could help me out...
TFR is offline
Old 09-19-2001, 09:33 PM
  #146
psycho's Avatar
TFR
I'm not sure what track temps you'll see, but my car was very hooked up with stock setup. Track temps on the tracks I run at are usually 137 degrees online and 134 degrees offline in the afternoon, and I run exclusively on asphalt (because it never rains in CA!) The only thing I did different was to put a couple dabs of Associated Black Grease under the friction damper plates. I used the stock rubber tires and stock inserts that came with my kit with the stock springs and could not break the car loose. I was running the Toyota GT1 body. I read somewhere that it has the best downforce of the Tamiya GTP bodies. One trick that I did to stop the rearend from rattling around was to cut small pieces of sedan foam inserts and punch a hole in them and put them over the rear body posts. The expansion pressure of the foam pushes the body against the body clips and it doesn't bounce around as much. Good luck at TCS!
psycho is offline
Old 09-20-2001, 11:44 AM
  #147
jcr
TFR you're going to race in hte TCS race. I can tell you that will will never get close to the 137degrees this time of the year for us. I say your car was pretty good last time. just work on your driving skill!
jcr is offline
Old 09-20-2001, 02:47 PM
  #148
psycho's Avatar
For those of you going to the Castle Classic on Sunday, get ready for some traction rolls. The parking lot was resurfaced and we should have nutty amounts of traction this weekend! I was there today and the surface is awesome.
psycho is offline
Old 09-20-2001, 05:24 PM
  #149
TFR
TFR's Avatar
Thanx psycho...
but i got it wrong, it indoor...
but you set up i will try when i have outdoor race...
thanx
TFR is offline
Old 09-20-2001, 05:25 PM
  #150
TFR
TFR's Avatar
JCR, oh ya?
thanx
ya, i think its pretty good too....
you're right about the skill.....i have to practice more....
TFR is offline
