Help, Lap timing on Futaba 3PK
Im hoping to get some help from all the people using the 3PK out there.
recently purchased one and i love it!
But the one thing im having trouble with is setting up the lap timer function. Im trying to set it up for 5min runs in practice with throttle to trigger the start of the 5min "race" and the button the the handle (under your middle finger) to trigger the laps/times.
How in gods name do you set the auto start function to the throttle,
and then how do you set the lap "trigger" to the finger on the handle.
Radio is in mode 3, so i have all the menu options open to me, but i cant seem to set it up correctly...... Crying or Very sad
Simon
Simon
I have one of the 1st gen 3PK's, but I hope it works the same way on the newer ones. To get it to start with pull of the trigger, you have to go into the timer menu and reset the timer (hold + and - simultaneously, IIRC some RST text will come on and the time will flash zeroes). After that it will start on the first pull. You can go back to main menu if you want and it will still work.
Lap trigger has worked from the beginning without any issues, but I never use it anyway, it's quite an effort to press it consistently at the same time whilst driving and disturbs my driving more than it's worth.
Simon
Simon
u have to assign a button for the lap timer to start and u have to hit that button every time u cross the line. you would normally set the button on the middle finger.
so its not really accurate only +/- 0.5 secs.
a better way to determine lap time is to put it in LAP function. say your average lap times are 20.10 seconds, set it to 20.10 seconds and the controller will automatically countdown and beep every 20.10 seconds.
very usefull to see if u are above or below your average.
Yawn,.. excuse me, You need to read the T3PKS manual to tell you how to set it up. I tell you, 3PKS manual book is not hard instruction and how to set it up.. manual is your best friend!
read, read, read, read manual book till gain your knoweldge and understandable how to use your lovely 3PKS!
Good Luck..
Good Luck..
