Hot set-up for TC3 asphalt???
I have been away from RC for awhile and I am curious what the hot set-up for a TC3 on asphalt? I am curious about shock oil, springs, tires and foam, gearing.....................etc. The more help the better.
Joe
Joe
At SRS I run the Baker Reedy setup with red/gold and Sorex 36s. Works fairly well.
setup
I run on a loose asphalt track with this
front yellow springs 60 wt oil 42 shore speedmind foams 1degree camber 1 degree toeout 4mm rideheight 4 degree castor blocks
batteries 3 in front 3 in rear
rear copper springs 60 wt oil 37 shore speedmind foams 2 degrees camber 3 toein blocks 5 mm rideheight
27 tooth pinion on a v10r matrix motor with tires at 2.42 width
I have won first 2 outings with this and 1 tq would have had 2 tq but wheel nut came off and gas car hit me in first qualfier(yes I am faster than a gas car)
This setup the car front is neutral to slightest push with car just a tad loose on exit of turn.
