Remove CA?
Remove CA?
I was gluing tire and I put too much CA. The CA went all over the wheel. How can I remove it?
exactly what i did! haha
loctite make superglue remover, use that.
or failing that use nail varnish remover. make sure it has acetone in it. the loctite superglue removers main ingredient is acetone.
sanj
sanj
Thanks, I'll try that.
just drive it on the street a little and it ahould wear it right off.
yep, that works well. i had a blob of CA once and back and fourth and there it went, no more CA on tires
I went to my local hobby shop. They have CA debonder.
i have herd that the debonder does not work that good
ya should of just worn it off.
Originally posted by Aku-Man
Yes, I just destory my new wheel. The wheel melted. Damn.
The Joys or tire gluing
Guys;
Next time try using one of the small applicator tips when gluing your next set. This really helps control how the CA comes out of the bottle. (from many glued fingers of experience later)
Best way to glue is to slightly "Pinch" a section of sidewall to pull it away from the Rim, then apply a drop of CA. go around the tire and do this in several places. If you apply too much, use a paper napkin to daub away the excess glue.
Once you've glued one side, wrap about 2 layers of Electrical Tape around the Bead to hold it tight. Use this procedure for the others, gluing 1 side at a time.
When you can no longer smell the CA on the Tire, remove the tape and repeat for the other 4 sides.
*Keep some DE-Bonder handy just in case*
