Old 05-09-2003, 11:19 AM   #1
Default Hot set-up for TC3 asphalt???
I have been away from RC for awhile and I am curious what the hot set-up for a TC3 on asphalt? I am curious about shock oil, springs, tires and foam, gearing.....................etc. The more help the better.
Dreamer is offline   Reply With Quote
Old 05-09-2003, 11:28 AM   #2
CGR's Avatar
At SRS I run the Baker Reedy setup with red/gold and Sorex 36s. Works fairly well.
CGR is offline   Reply With Quote
Old 05-10-2003, 12:14 PM   #3
Trader Rating: 14 (100%+)
Send a message via AIM to Fuzzchop
Default setup
I run on a loose asphalt track with this
front yellow springs 60 wt oil 42 shore speedmind foams 1degree camber 1 degree toeout 4mm rideheight 4 degree castor blocks
batteries 3 in front 3 in rear
rear copper springs 60 wt oil 37 shore speedmind foams 2 degrees camber 3 toein blocks 5 mm rideheight
27 tooth pinion on a v10r matrix motor with tires at 2.42 width
I have won first 2 outings with this and 1 tq would have had 2 tq but wheel nut came off and gas car hit me in first qualfier(yes I am faster than a gas car)
This setup the car front is neutral to slightest push with car just a tad loose on exit of turn.
Fuzzchop is offline   Reply With Quote
Premounts for asphalt jdearhart Electric On-Road 6 03-20-2008 05:22 PM
Asphalt '07! Arun Georgia Racing 196 08-08-2007 07:52 PM
NIB BMI T2 Asphalt Chassis Guo Chean R/C Items: For Sale/Trade 5 04-15-2007 12:10 AM
1/12 for asphalt sampaio Electric Off-Road 1 05-13-2006 10:38 AM
indoor asphalt HotPink Electric On-Road 22 07-26-2004 12:48 PM
SEO by vBSEO 3.5.0
