Old 08-25-2007, 04:40 AM   #1
Default pro- trak problems
hi all, i went to charge my batteries about 5 mins ago and my protrak wouldnt charge them.
it carried on as it would charging them but wouldnt go up to 5 amps. and wouldnt change the ampage either. it just stayed at 3 amps, every 30second it would change bak to 0 amps by its own. it just wouldnt charge them. i thought id leave it and see what it done. i was charging orion 3700's and it sed that they had peaked at a capasity of 360mah. thats obviously not right. i also makes noises the whole way through the charge, neva done it when i first got it. just started recently.
could anyone tell me whats wrong? with it cos i reli done know. And dont particulary want to just chuck it away and have to fork out 300pound for a new one.
jordys jrxs is offline   Reply With Quote
Old 08-25-2007, 05:41 AM   #2
..........what kind of noise???
A friend of mine had similar problems times ago... his Protrak unit simply wouldn't exceed 3 amps...
There was a faulty fet... but no noise at all!
Send Phil Haines a mail!
il-gufo is offline   Reply With Quote
Old 08-25-2007, 06:13 AM   #3
like beepying noise. i must sort it out.
Old 08-26-2007, 04:10 PM   #4
Hi, did respond to you on another thread, but you hadn't mentioned the beeping noise. Likely explaination is 12V supply is too low. The Pro-Trak decreases charge current to compensate (reduces the pull down on a 12V battery). Screen should come up with a message at the same time to say supply voltage is low, but it is only on the screen while it beeps.
coppins999 is offline   Reply With Quote
Pro Trak NismoSkyline17 Electric On-Road 520 11-09-2009 07:33 AM
Pro Trak BMS chrisHN Singapore R/C Racers 0 12-05-2007 03:33 AM
Pro Trak 30 crimson eagle R/C Items: For Sale/Trade 0 11-12-2004 09:51 AM
Pro-Trak BMS Glenn Atterton R/C Tech Site Forum 1 11-21-2003 10:26 AM
Pro-Trak Is The Best CRASH Electric On-Road 5 04-13-2002 05:36 PM
SEO by vBSEO 3.5.0
