Old 05-08-2003, 11:30 AM   #1
doublest's Avatar
Send a message via MSN to doublest
Default MR4 Servo Saver help
Hi in my instructions it says that the bolt bit has to be 2mm or more from teh bootm ofm the saver. On mine that is very tight and cant even move the servo saver.
When i losen so that its inline with the bottom of the srew thread its loose enuff so that if if i was to crash the servo saver wud work.
What shud it be like.
doublest is offline   Reply With Quote
Old 05-08-2003, 11:36 AM   #2
sosidge's Avatar
It's your call - the looser setting will protect the servo more, but could also feel less direct in the corners (as the servo saver absorbs some of the movement).
I would try the settings back to back - if the steering feels fine to you with the looser saver setting, use it, as you'll protect the servo. I have the saver in my BC (buggy version of the TC) set looser, and I've not had any problems.
Old 05-08-2003, 07:16 PM   #3
dtm's Avatar
Send a message via ICQ to dtm
Turn on your car and TX. Hold the front wheels and try to "release" the servo saver by turning the wheel. It should be difficult to turn but the servo should stay in position. Too loose and your steering may wander. An easy way of finding if your servo saver releases when you run the car is to glue a thin strip of paper across the 2 halves. Run the car at normal speeds and don't crash........at the end of the run the paper should be intact. Crash and it should not be intact!
dtm is offline   Reply With Quote
Best Servo Saver... Still Bill Electric On-Road 7 02-17-2008 11:52 AM
FS: Xray M18 Kit + Micro Servo Saver, Servo and Receiver paulsrc R/C Items: For Sale/Trade 7 12-20-2007 06:38 PM
Airtronics Servo - 94357 w/ Servo Saver afr0sch R/C Items: For Sale/Trade 5 08-05-2007 05:43 AM
Tamiya Servo Saver with Hitec Servo old-man Electric On-Road 2 07-13-2006 06:08 AM
RC18T servo, servo saver, and steering rack Bansheeman R/C Items: For Sale/Trade 0 07-27-2005 08:27 PM
SEO by vBSEO 3.5.0
