Old 08-21-2007, 09:51 AM   #1
Dan415ms's Avatar
Novak 3.5R with a Nosram Matrix Evo 07?
Hi All,
I have a Novak 3.5R motor and a Nosram Matrix Evolution 07 speedo. The Matrix Evo 07 is basically the same speedo as the LRP TC.
My question is, will the Novak motor be OK to use with the Nosram speedo? The UK distributor has advised against using the Novak 3.5 with the Nosram although the ESC Specs say it can take down to 3.5 turn brushless.....
I remember seeing someone using an LRP TC brushless speedo with a Novak 3.5r motor and as the LRP and Nosram are basically the same speedo hopefully this will be fine?
Any advice welcome?
Dan415ms is offline   Reply With Quote
Old 08-21-2007, 04:37 PM   #2
Drewdc90's Avatar
I've never run the LRP or Nosram but i doubt you would have a problem.
-Xray--Nosram--Orion--Trak Power--Duratrax--Spektrum--Futaba-
Sunshine Coast QLD AUSTRALIA
"If you stand still long enough you'll go backwards"
Drewdc90 is offline   Reply With Quote
Old 08-21-2007, 04:40 PM   #3
I can't believe there would be a problem, especially if you are running 5 cell as the wattage thru the SC is reduced by 16% anyway
exint2 is offline   Reply With Quote
Old 08-22-2007, 02:19 AM   #4
It should be no problem, but you should check the sensor(cable) of the Novak motor, I don't if it has the same wiring as the LRP/Nosram or as the GM. They both use a different sensorcable, so you should check that out..
Rick Thomson is offline   Reply With Quote
Old 08-22-2007, 02:47 AM   #5
thachowman's Avatar
Trader Rating: 28 (100%+)
The novak sensor wire is the same as the LRP one , I run a novak 13.5 on my LRP TC without a problem... And they should definately handle down to a 3.5 as I run one on my as well...
Andrew "Chow" Clough
Fraser Coast RC Car Club/FCRCCC :President
Yokomo - Futaba - LRP - Paint Made Special - Muchmore
thachowman is offline   Reply With Quote
Old 08-22-2007, 06:23 AM   #6
ROBORAT's Avatar
Send a message via Yahoo to ROBORAT
the novak and LRP sensor wires are the same. i just ran a race last week using my LRP TC Spec with a novak 3.5 and had no problems.
ROBORAT is offline   Reply With Quote
Old 08-22-2007, 07:26 AM   #7
Send a message via ICQ to Jan Larsen
Same here. Ran a Novak 4,5 with the LRP TC speedo (same as the Nosram one) with no problems at all.
Jan Larsen is offline   Reply With Quote
Help nosram matrix evo 07 benste Singapore R/C Racers 1 03-09-2008 11:12 PM
LRP(Nosram) Sphere(Matrix) Competition(Evolution) vs. Novak GTB-4cell Tral Electric On-Road 5 11-01-2007 03:10 PM
Nosram Matrix ( Where to buy ) A Ilievski Australian Racing 12 01-09-2007 11:17 PM
Nosram Matrix ( Where to buy ) A Ilievski Electric On-Road 0 01-06-2007 04:54 AM
Nosram Matrix Evo Problem! Jenko Electric On-Road 1 11-22-2006 02:35 PM
SEO by vBSEO 3.5.0
