Old 05-08-2003, 12:04 PM   #16
BendingCorners's Avatar
Location: Orange County TrackMasters "The Home of R/C Champions"
Default Deans Blackbox?
How low of voltage does the deans blackbox discharge batteries to?
BendingCorners is offline   Reply With Quote
Old 05-09-2003, 08:35 AM   #17
RCBuddha's Avatar
Trader Rating: 33 (100%+)
I've got some questions:
Charging Question:
I have a milienium pro, and i've been using the NIMH mode, but I understand from Novak's website that I can use the NICD Linear mode to charge my 3000 packs. What should I set the thresholds at? I've read .5mv, or should I go higher?
Discharging Question:
I've been using a Dean's Light Bulb discharger and watching the voltage go down to 5.4, but I've read to then put the cells onto a discharger tray like the Integy Octane 2 or the Real Time Tray 2. Then wait until the lights go out and pull off. Is this correct? What does the tray take the cells down to?
After a night of racing, and after discharging your packs, how do you store your packs? Do you put a charge into it? Or do you leave it be?
Thanks for the help,
RCBuddha is offline   Reply With Quote
Old 05-09-2003, 01:34 PM   #18
After a night of racing, I leave the pack alone.
Before i charge them again next week, I put the packs on the lights, then when it cuts off, I put the pack on the discharge tray for about 30-45 minutes.
Try to time it so you take the pack off the tray about 10 minutes before you charge.
Lowest mv setting possible. In fact, after this discharge technique, the packs will take a full charge (notice if you don't fully discharge you get charge reading of 2500 mah at peak.) . If you cut the pack off early, I notice more punch! Stop them at around 2700 mah. Thats really plenty of juice for stock and most mod, unless your running 8t motors
Pit Crew is offline   Reply With Quote
discharging koolkidd Electric On-Road 25 06-08-2007 01:43 AM
Pulse vs Linear DISCHARGING (also vs Multi-step discharging) akuhon Electric On-Road 5 01-01-2007 10:58 PM
Discharging and Discharging Question jeffbhhs Electric On-Road 5 12-14-2006 05:34 PM
discharging wallstreet Rookie Zone 3 04-01-2005 06:12 AM
discharging pro3racer Electric On-Road 4 10-04-2003 07:11 PM
SEO by vBSEO 3.5.0
