gearing lrp 13.5
gearing lrp 13.5
currently i am running the novak 13.5 sintered motor im running a t2 007 at 112/42 and coming off track at 140 degrees i want to run my new lrp 13.5 and i need to know if it should be geared the same i do not know if it is sintered im using the lrp touring car edition esc
Gear it the same and check temp at 4 minute mark. If its too cold gear up a tooth and kind of keep checking temps and keep gearing up a tooth until you are hitting full throttle 2/3 down the stright and the temps are under 160, you shoudl be fine.
-Shookie <><
Here is a place for ya..
http://www.speedtechrc.com/store/ebp...id=413&id=6955
They are out of stock as most hobby shops....
When you see one grab one....It really helps the motor.
Hope that helps,
-Shookie <><
