Old 05-06-2003, 04:39 AM   #1
Send a message via AIM to deanspoors
Default 40fm futaba micro reiever-how long should the antenna be?
how long should the wire be?
deanspoors is offline   Reply With Quote
Old 05-06-2003, 04:52 AM   #2
hi there,
i worked it out to be 470mm or 230mm.
if anyone is wondering how you work it out:
>wavelength = velocity / frequency
velocity is the speed of light
put some numbers in
>wavelentgh = 3e8 / 40 e 6
= 7.5m
then you need to keep dividing by 2 until you get a nice manageable length. in this case 7.5m /16 or 7.5m / 32
and it is the same length as the wire on a fuataba!
hope that helps
schumacher is offline   Reply With Quote
Futaba 2PL Antenna Ranger1069 Radio and Electronics 1 09-07-2008 02:29 PM
WTB 2 Losi Micro or Mini Transmitter Antenna rokit408 R/C Items: Wanted to Buy 0 01-23-2008 04:06 PM
Length of Airtronics Micro Receiver Antenna?? BobbyDoyle Electric On-Road 0 06-09-2006 11:01 AM
Antenna Length for a Futaba R123F? atlrcracer Electric On-Road 3 06-06-2004 06:21 AM
Wanted ASAP: futaba 3pk antenna TambokGT R/C Items: Wanted to Buy 2 03-18-2004 01:45 AM
SEO by vBSEO 3.5.0
