degreasing bearings
What will break down the grease in the bearing for easy removal .
What is the best oil for lubing the bearing. |
remove both seals and blast with motor spray then lube with trinity royal oil.
Re: degreasing bearings
Originally posted by sportracer What will break down the grease in the bearing for easy removal . What is the best oil for lubing the bearing. Spray the bearing out with motor spray, and then re-lube it with a bearing oil. I use Team1 bearing oils, Trinity and others also have bearing oil. Now you can either replace the shields, or only the outside shield, or neither. I usually replace the outside shield, leaving the insides off, but still sealed by the carriers. If you aren't racing, it is not worth it to degrease your bearings. If you hit the wall often, it's not worth it either. |
I take one sheild of each bearing and use motor spray to degrease them then apply any bearing oil to lube them. Bolink, Trinity are a few companies who make bearing oil.
