Xray T2'008
#1231
You can fit it without the hard case, or let it hang off the chassis a little, this way the top desk does not cause any issues. Obviously, good double-sided tape will be needed to sure it.
If you want to play with a high-capacity battery that will fit, check out the MaxAmps 6000, it it 22mm tall.
#1232
The diffrerence in spring pre-load will make it near impossible to get equal. Also, the Hudy Balance Buttons are fairly easy to balance anything on, it just gets you in the ballpark, which is usually good enough. If you want to get more accurate, get the Round Balance Buttons, I think IRS makes them.
#1233
#1234
R/C Tech Elite Member
my T2 008 running Lipo was under weight by a ton. I recently got two scales to balance both front to back and left to right using a technique described by John Stranahan:
http://www.rctech.net/forum/showpost...4&postcount=32
i added a ton of weight to my T2 and even went over the weight limit of 1525g to get a better weight balance.
#1235
Man I never would have tried that....I have four pocket scales I purchased from Habor Freight...I can actually measure at each wheel,nevr thought of trying the 2 scales not sure of the accuracy...50/50 I would think would be easy to obtain and I have that Due to my LF and RR having Identical weight and my RF and LR have nearly the same weight which would give me 50/50 but my issuie is between LF/RF and RR/LR...But I am probably over thinking it thats why I wandered if anyone has balanced there car at all four tires...It might be imposible...
#1241
#1242
I am 1 members newly assist at all the friends's forum. At present i are living in Viet Nam. Me is practise to playing streetcar, muscle in on this place for extra study . Thanks
#1243
how many gear for motor Novak brushless 3.5 on Xray T2 007 ? Thanks . Middle track .
#1244
The new aluminum dampers Will improve the performance of the original shock absorbers?
