Xray T2'008
#1098
Shock Assembly (new to xray)
When assembling the shocks, there are two small o rings, one thinner one that goes around the base of the shock body and the thicker one on the piston shaft.
Do most of you build your shocks without the o ring that goes on the piston shaft? What difference does this make?
Thanks,
Phillip
Thanks,
Phillip
#1099
I sure do! I ran it this past weekend at the Nat's warm up race and it was MONEY! I ran a T2 when they first came out outdoors and it was such a nice car. The quality is so much better than some of the cars I have ran since.
Thanks,
Phillip
Thanks,
Phillip
I run the O ring. It does 2 things. First it will help to seal the shock. Some seepage is OK. The second thing it does is it will slow the reaction of the shock a little.
#1100
Shock Assembly
Thanks dodgeguy! That is what I was thinking. I just noticed on many of the setup sheets that NO was checked next to "O-ring On Shaft" section.
Appreciate the feedback!
#1102
Thanks,
Phillip
Thanks,
Phillip
#1103
Kn7671, Those are the spurs I have. I was thinking about it yesterday and thought, Set the gear mesh with the open screw (having the other with little play) and then lift the spur up enough to tighten the other screw and then tighten down the spur once again. Thank you for replying.
#1104
HTH
Mark
#1105
Hey Guys a couple quick questions if anyone minds answering. I'm currently still building the car. While mounting up the front sway bar i find its very easily hitting the axels with just a bit of suspension movment. i know the links are adjustable but it doesnt seem like theres gunna be a lot of threads holding the 2 ends together if i lengthen them up. And i need a baseline gearing setup
Im running a Novak 3.5BL GTb speed controller and Orion 3200 lipo with rubber tires. Any help would be great
For your base-set up go to the x-ray home page and in the corner on the right above click the forum select your car and look in the set-up sheets
for a simulair surface as your home track, I know for sure you find where you looking for.
Buy, Ed IJ t2' 008
#1106
I just bought my new 008 and I m about to install the electronics. Have you seen any pics around showing a brushless 5-cell setup, where I could get some ideas on how to wire the thing.
Thanx
Thanx
#1108
Xray release new upper deck
