Xray T2'008
#1906
They mostly run 1:5 Gas TC cars there, but we've divided the time on the track between us more or less fifty-fifty, when the electrics show up....
Regarding the gearing, I had completely ignored the internal gearing,
I've done some research and found out that on the 008, the internal gearing is 1.7 or 1.9..
That would mean that the math would look something like this (if in fact the internal gearing ratio is 1.7):
Spur/Pinion * internal gear ratio = 3.500
Spur/Pinion * 1.7 = 3.500
Spur/Pinion = 3.500/1.7
Spur/Pinion = 2.058
Spur/2.058 = Pinion
84/2.058 = 40.8...
How big a pinion could I actually fit in the '008?
Would it make sense to go smaller pinion and spur?
Spur/Pinion = 2.058
Spur/2.058 = Pinion
84/2.058 = 40.8...
#1908
Appreciate the offer, but for starters feel free to try and answer in this thread ;-).
Counted the teeth on my pulley set and I'm actually running the old original pulley set, the 38/16 set, so running with an internal ratio of 2.375 :-(..
This still doesn't change the fact that I would love to know the biggest pinion that I'll be able to fit in the car with the 84 teeth, 48pitch pulley that I've got on there.
I'm also looking for a great EU vendor who sells spurs and pinions for the T2'008.
I'm also looking for a place that sells the replacement pulley set for the T2'008 which alters the ratio to (34/20) 1.7.
Hoping someone here can help me out with some of my questions.
#1909
Appreciate the offer, but for starters feel free to try and answer in this thread ;-).If I must..ok
Counted the teeth on my pulley set and I'm actually running the old original pulley set, the 38/16 set, so running with an internal ratio of 2.375 :-(..The 08 came with two internal ratios, 1.7 & 2.375...forget the 2.375 & use the 1.7
This still doesn't change the fact that I would love to know the biggest pinion that I'll be able to fit in the car with the 84 teeth, 48pitch pulley that I've got on there.the pinion size will depend on the spur size of course...it would be helpful to know what motor & ESC you're running, THEN, can give you a starting point
I'm also looking for a great EU vendor who sells spurs and pinions for the T2'008.A Main or Stormer Hobbies
I'm also looking for a place that sells the replacement pulley set for the T2'008 which alters the ratio to (34/20) 1.7. Again, A Main or Stormer Hobbies
#1910
Hey Brokin, really appreciate it.
I bought the car used, so I'm stuck with the 2.375 ratio.
I'm running a Robitronic 13.5 turn motor with an Exelorin ESC.
I'm aiming for an FDR of 3.500, 'cause thats the limit in the Super Stock Class here in Denmark.
#1911
I bought the car used, so I'm stuck with the 2.375 ratio.not if you don't want to be...$20 and some labour & it's changed
Spur divided by pinion multiplied by internal ratio which gives you FDR, then divide this figure into 197.8 & that will give you your rollout (within a pooftenth)
Try & balance spur/pinion sizes so that you're pinion isn't too big
#1912
Aluminum Steering Block Ball Bearing
Hi guys,
I have this Aluminum Steering Block and I have to replace the ball bearing. However, I try to insert 5x10 x4 ball bearing but it was lose...I guess it is slightly bigger than bigger than 5x10 x4 ball bearing..
If you know please kindly tell me . Million Million thanks
#1913
Hi guys,
http://www.nexusracing.com/product_i...oducts_id=1457
#1914
The aluminum steering blocks use a 3 x 5 x 9mm bearing. If yours is loose then you must not be using the the composite sleeve that the bearing presses into.
please correct me if i am wrong
#1916
i'm a big fan of purposely omitting the plastic bushings in favor of a more robust (larger) bearing. the 5x9's blow out if you look at them wrong.
#1917
the xray branded type use 11x5x4. not sure if the epic knockoffs use the same geometry, but i would feel confident to bet on it.
#1919
Too bad I have lost all the sleeves.. i will try to order 5x11x4.. hope is gonna to fit in
