Many discounts and deals on RC products and parts can be found on UltimateCoupons.com.
Consider visiting BensBargains.net for great discounts on remote control products.
Old 11-07-2009, 04:04 AM   #1816
Sith Lord's Avatar
Originally Posted by rcko View Post
Nexus typically has the L shaped weights. I bought them and am currently using them, but truthfully, a strip of lead on the battery pack works just as good... I weighthed all my packs and got them to weight equally. Some of the packs, like the Orion pack, required lead to weight the same as the Thunder and SMC packs. I tried to match battery CGs as cell. This way the overall car balance is not changed as I changed batteries.
I use the L shape pieces to help support the battery from moving outboard. One of the larger trapezoidal pieces supports the battery from moving inboard.
For batteries with the molded cell tubes underneath, what I have done is insert the pack upsidedown. Then very carefully drilled through the battery case so I can insert the bullet connectors. I also ID the positive terminal with a dab of red paint. Works like a charm, allows the battery to seat nice and flat low on the chassis.
Thanks, but weight is not the issue (yet). I need to get the battery physically taped/strapped in the car first. Can't do because of where the corally tubes are. The Xray weights and Bitty Design tray move the battery outwards to clear the top deck.
Hadn't considered the drilling bit even a possibility
Beware of the Dark Side
Sith Lord is offline   Reply With Quote
Old 11-07-2009, 07:29 AM   #1817
Akhor's Avatar
Currently my rear shocks (008) feel like the are not smooth.
I've tried changing the oil and the bottom O-ring on the shaft. HOwever it still does not feel smooth..
Am I missing something?
Losi 8ight 2.0
X-Ray 008 EU
Futaba
Fireball Glow Plugs
Akhor is offline   Reply With Quote
Old 11-07-2009, 01:10 PM   #1818
Con
Did you bleed them? Air bubbles in the oil will make them feel "rough".
Con is offline   Reply With Quote
Old 11-07-2009, 01:13 PM   #1819
Akhor's Avatar
I let them sit for a while then bleed them out of the top. I tried adding Green slime to the o-ring, and this made one of them feel smooth..
Maybe I'll just let the other one sit for an hour or so to make sure the bubbles are out..
Losi 8ight 2.0
X-Ray 008 EU
Futaba
Fireball Glow Plugs
Old 11-10-2009, 08:54 PM   #1820
waOscar's Avatar
Send a message via Skype™ to waOscar
check that your shafts dont have a slight bend. even a slight bend will make the shock feel "grabby"
Xray T2 009 - my asphalt chassis
Xray T2 008 - my carpet chassis
Xray T2 009 - Laura's current
Tamiya TA05 - Laura's very successful 05 now retired.
Tamiya TT01 - hack for family and friends
plus couple of old shuie off roaders
waOscar is offline   Reply With Quote
Forum Jump
Almost new Xray T2'008 Sean R R/C Items: For Sale/Trade 9 08-08-2008 01:17 AM
FS: XRAY T2'008 EU 6 CELL RC MARKET R/C Items: For Sale/Trade 4 06-27-2008 10:58 PM
FS: *NEW IN BOX* XRay T2'008 US Foam Spec limbohz R/C Items: For Sale/Trade 8 04-17-2008 10:20 AM
Xray T2'008 EU 6 cell Kit yyhayyim R/C Items: For Sale/Trade 17 02-05-2008 08:06 AM
XRAY T2'008 RC MARKET RC Market 1 09-10-2007 09:20 AM
Powered By: vBulletin v3.7.4
Content © 2001-2008 RCTech.net | Privacy Policy | Terms of Use Privacy Policy | Terms of Use
SEO by vBSEO 3.2.0
