TRF Chassis on TA04
Does a TRF Carbon Lower chassis fit a TA04??? because the standard TA04 Lower Chassis doesn't have holes for the saddle battery pack.:nod:
:confused: :confused: :confused: |
Does anyone Know???
Try this one.
ITEM 53494 (OP494) TA04 Light. Carbon Lower Deck side by side chassis 53494 Works for me. Tony |
Yah but i wana set it up so its like a stratle so the car has better balance. But thanks Anyways. :blush:
Originally posted by TAO4R Yah but i wana set it up so its like a stratle so the car has better balance. But thanks Anyways. :blush: Hard to find in HK.. a US spec parts |
Originally posted by TAO4R Yah but i wana set it up so its like a stratle so the car has better balance. But thanks Anyways. :blush: Front to back on the other hand is different as you have more weight towards the front with sadle packs. But that Tamiya chassis will do it, failing that Integy also used to sell one. Check out the Integy website in the Tamiya parts section. Tony |
The Integy one is cool but is it allowed in tamya races??? If not that ill go with the tamiya one. Thanks for you help :lol:
Only Tamiya parts allowed in TCS! I wouldn't worry too much about the forward weight distribution the carbon tub is cheap and does a great job. My TA04 is a very easy car to drive....."almost" as good as my Xray!:sneaky: :D Concentrate on the setting more.
For TCS you have to get Tamiya parts.
My 04 runs very nicely with the carbon tub chassis and a 9double in it. Tony |
