Old 08-10-2007, 10:43 AM   #1
Default car pulling to the right; why?
My TT01 pulls to the right at first. Easy enough to trim out, but as the car warms up it begins to come back. Say 1/2 way through a pack, I begin to adjust it back, and it goes fairly quickly to neutral for the rest of the run. What's up with that?
swannco is offline   Reply With Quote
Old 08-10-2007, 10:48 AM   #2
habis's Avatar
Waco electronics
have had the same experiance.
sometimes "low range" transmitters/recievers has problems keeping the frequencies....
wont have that problem with "the top of the range"
habis is offline   Reply With Quote
Old 08-10-2007, 12:20 PM   #3
I'm not sure I know what u mean by low range and top range. Are u referring to the AM v. FM band?
Old 08-10-2007, 01:54 PM   #4
had that same problem,,, all i did was replace my servo then everything was running well again... you can also try checking if your receiver is receiving enough power from the batteries,,, try to check for bindings as well on your drivetrain, make sure that your front left and front right tires are spinning freely also make sure that the uprights or every part that has something to do with steering are not overtightened.
imel24 is offline   Reply With Quote
Old 08-11-2007, 08:03 PM   #5
thanks imel24, i will check for binding. i have another servo, maybe i will just swap it out real quick. i did replace the batteries and that got me better response, but it still pulls at 1st then comes back to neutral.
Old 08-11-2007, 08:08 PM   #6
Mr. Shookie's Avatar
R/C Tech Charter Subscriber
Send a message via AIM to Mr. Shookie Send a message via MSN to Mr. Shookie
Cheap servos can cause it not to center right and will kind have a mind of its own.
For serious racing a digital servo that is in the > $60 range is going to give you more consitant results.
But if you are limited to a cheaper servo try to find a nice higher dollar servos used.
Trust me, I went through 3-4 cheap servos.
Hope that helps,
-Shookie <><
All who love the LORD JESUS I praise with you.1 Cor 10:31
Team HOLY Rollers (Team Manager)
The Church is a Hospital for Sinners not a Museum for Saints.
RcTech Feedback <>< RC Tech Subcriber #92
Mr. Shookie is offline   Reply With Quote
Old 08-11-2007, 08:49 PM   #7
SpidarX's Avatar
Make sure all your bearings are smooth. A bad bearing on one side can cause that too.
SpidarX is offline   Reply With Quote
Old 08-11-2007, 10:07 PM   #8
Yeah, I wondered about a bad bearing, but I couldn't figure why it would stop pulling after awhile. I might try swapping the bearings from side to side though. That would prove or eliminate the question and should be easy enough to do.
The servo is a JRz590 with metal gears, so its decent quality [I think, but maybe not?]. Not sure right off the top of my head what brand my other servo is. I might just swap it out to see if the problem persists.
Mostly its just curious and slightly annoying. The car is easily adjusted on the fly with the trim button, but I like things to be right, and mysteries are best on video or in paperback, not on my r/c cars!
Old 08-12-2007, 05:26 AM   #9
Trader Rating: 22 (100%+)
In my xrays and a corally that I had, when the bearings go bad, it would pull hard and fast, and never come back. My bro was using a Hitech servo, that had no clue (the servo) where center was (although, my bro dont have a clue sometimes). He switched to a JR 590 and didnt have a problem. Do yourself a favor, and go for a better servo (faster and more torque). It is quite simply one of the best upgrades that can be done
convikt is offline   Reply With Quote
pulling truck need help MADMAN23 Electric Off-Road 5 10-04-2007 05:24 AM
Pulling truck Saber186 Oval, Larger Scales and More 1 06-06-2006 01:44 AM
Get hooked on pulling ??? oldpinky Track Locator Forum 0 05-11-2006 06:10 PM
Associated pulling out of the USA??? tunnelhead Electric On-Road 33 04-25-2006 07:22 PM
Rc Pulling j_popelier Wisconsin & Illinois Racing 0 09-15-2004 08:09 PM
SEO by vBSEO 3.5.0
