Old 05-04-2003, 10:32 PM   #1
Default Motar degree timing?
My Super rooster ESC says that modified motars should be timed at 0* I believe my 9T is at 10* I have no tools other than screw drivers and allan renches. Is it possible for me to fix this. If so how?
Dayne is offline   Reply With Quote
Old 05-05-2003, 02:01 AM   #2
fasterdanu's Avatar
first thing release the brush springs then pull the brushes out a little the there will be 2 screws oposite each other on the endbell undo these a little then just twist the top so that the lines on the can meet up with the lines one the endbell evenly this means 0 deg of timing.
be aware that your batteris will go flat faster the car will take off a little faster and have more touqe but less top end speed if u dont understand i can give u a pic
fasterdanu is offline   Reply With Quote
Old 05-05-2003, 02:09 AM   #3
Dear Sir,
Can you tell if I am correct ?
Say +10 degree = higher end speed, lower low end torque ? Or Vice Versa ?
Anthony Yuen is offline   Reply With Quote
Old 05-05-2003, 02:20 AM   #4
sosidge's Avatar
Motor timing is slightly more complex than that.
First point - leaving the motor at it's factory-set timing is best for most people.
Second point - the Super Rooster is only saying 0deg (maybe referring to a twin motor setup?), for a single motor leave it with the standard advance.
Timing is advanced by turning the endbell anti-clockwise as you look at it. Motors perform better with a small amount of advance.
Small amounts of advance (6-12 degrees) improve efficiency, and give a small increase in power.
Large amounts (18-24 degrees) increase power, but efficiency drops off. Going too far will make a very innefficient motor, and eventually the power will start to drop off.
Old 05-05-2003, 02:41 AM   #5
Thanks ! This is simply but easy understanding information for a rookie like me.
Brush cutting,timing,degree protyne Rookie Zone 3 11-21-2008 07:24 PM
help me... How do I find the zero degree timing on an unmarked motor can? dinorider Electric On-Road 2 07-09-2008 12:43 AM
Trade T2 2 degree front caster alum blocks for 4 degree straightaway R/C Items: For Sale/Trade 0 01-28-2007 12:01 PM
Jaco Nitro Shoes 16 pairs(front 0 degree, Rear 2 Degree offset) EJRacer R/C Items: For Sale/Trade 0 04-03-2006 12:13 PM
help with hpi sprint and 9T double motar. Dayne Electric On-Road 6 05-05-2003 01:56 AM
SEO by vBSEO 3.5.0
