calculating FDR and rollout
So I get FDR, and I use gearchart.com on a rgular basis, but I don't understand the difference between FDR and Rollout, could someone gimme a short explanation?
Also, what size are the Take-Off RP30's and CS27's, for calculating rollout? TIA:batman: |
Originally Posted by Blisster
(Post 3554340)
rp's and take0ffs are 63mm
rollout is how far your car travels in one tire rotation.
how far it rolls in one tire rotation? That would be the circumfrence of the tire.:confused:
One revolution of the motor/pinion=how far the car travels.
I think |
ok, if im not mistake to calculate rollout, you mount the wheels on the chassis ans make a mark on the wheel. line up the wheel with the mark pointing down, then roll the car until the mark is back in that position. then measure the distance from where you sat the car to the distance it travelled to get the mark back to it's original position.
Roll out is how far the car travels for each rotation of the motor. Example - a Xray geared 31/116 with 56mm tires has a roll out of 27.64mm. Rollout will change as tires get smaller, and requires "gearing up" to maintain the same roll out.
FDR = spur / pinion X internal Roll Out = tire diameter X 3.14 / FDR |
Originally Posted by A. Rhodes
(Post 3554437)
FDR = spur / pinion X internal Roll Out = tire diameter X 3.14 / FDR where do you get the 3.14 from is this a common number |
Originally Posted by stuey
(Post 3554519)
rollouts helped me when I wasn't going as fast as the guys I was racing with who was running 19 turn. I found out that I wasn't geared the same because our rolouts were different. I use the gear wizard calc but you have to find out what your car final drive ratio is. You can usually get that from the manufacturerer. I was gearing my cyclone at 100 by 32 when the rollout showed I should be gearing at 100 by 38.
Once i found that out, I was just as fast as they were. make sure that you take the motor in consideration. when I gear my Komodo 19turn i use the 38 tooth pinion, but when I run checkpoints, I use a 42 tooth pinion because that motor likes to be geared higher than any other 19turn. Rollout calculator is great but just make sure you keep an eye out on your motor as well as to not overgear it and burn the comm. |
A. Rhodes - Thanks for the explanation, just what I was looking for! :cool:
Elboogie - Yeah, i ffigured that out when I switched to the Novak 13.5, I had to gear WAY up to get any speed out of my car (was geared at about 6.8 on my normal brushed motor, geared it up to a 4.5 with the brushless). I temp my motor after every run. |
ELBOOGIE
Elboogie - I have sent you PM's and you have not replied. Can you please get in touch.
I have an Excel sheet that work great if i could post it. Can someone tell me how?
Well I have a question
When looking at FDR's does a lower, say 4.50 ratio mean that the car would be faster with less torque to like 5.0, and vice versa? So pretty much the smaller the numbers, the more speed? Im getting all confused, I was recomended a ratio between 4.50 and 5.0 and im looking at a FDR sheet from gear chart, and im looking to see which spur will work best with the pinions I have, to get the ratios I want |
