Changing electrics
Im woundering if I need to reset the settings on my EX10 helios before I change over to a new car with new servo + receiver?
Does the transmitter settings need to change if Im using the same servo but in a different car? thanks. |
Yes.
oh no........spammer
Yes you will as the end point will pretty much be different.
if this is a completly new car and your not going to run your old car you can just redo all your set up. shouldn't take to long. Or, if you radio allows it. and your still going to have your old car as a back up or what ever. you could alway set up another model. as some radio allow from 3 model to 20 different setting for different cars. I hope this helps |
