IRS Balance Tools for TC and 1/12th
i got these new balance tools from IRS that really worked awesome.they are brand new so i thought i would share some pics and info. they allow you to set the balance of your car very easily and are very precise.they have 2 pins that fit into the holes on your chassis and you set the car down.you can do this with or without wheels on the car.it allows the car to roll on the 1/2 ball very easily for the most accurate balance measurement.they are simple to use and the most accurate i have used.
that is brilliant.
I e-mailed IRS about them a few days ago when I placed my order for the new lower arms...never got a response.
tools
Good
Location: Louisville, KY!.. USA!! ....Home of http://www.fastharry.com
forget the part number...
just call dave at Irrgang...phone #(609)476-2371..tell him you want the balancers.....
Just ordered mine...12.95.....5.50 shipping.....going out TODAY.....
See you unbalanced bastids at the track!!!!!!!!!!!!!!!!!!!!!!!!!!!
Thanks Jason for putting our Balance Buttons (P/N IRS3020, $12.99 for 2) on RCTech. They will be on the web site within a few days but they are in stock now. Anyone can call and order them @ 609-476-2371.
The Balance Buttons are extreemely easy to use. I simply drilled 1 5/64" hole in each end of my car and then placed the car on them. Immediately I saw the car was heavy on 1 side. I moved my electrics around and the car balanced out. Sometimes you might have to add some lead to finish the job. This will require you to use less preload on your springs to get the tweak correct.
I will let everyone know when they are on the web site but for now you can call to get them.
Regards,
Dave Irrgang aka DiffDude
Regards,
