Old 05-02-2003, 12:45 AM   #1
alan1467's Avatar
Default Indi Motor Checker-Dyno
I have just bought one of these but I'm having problems can anyone help????
If you connect the motor leads before you press start it does not work. The motors just buzzes but not turn. You have to switch it on then connect the leads to the motor then its ok. Is this right or is the unit faulty???
Tamiya TRF - Tekin
F104W Pro - CRC Gen X10
alan1467 is offline   Reply With Quote
Old 05-02-2003, 02:27 PM   #2
fasterdanu's Avatar
if u have any phone numbers for the company call them and ask what's up, it might be nothing or u might have to send it back for repairs.
1 other thing are u using a 12v supply or a wall plug to power it
if u are useing a 12v battery then u need somthing rated arround 100amps to get accurate results if u are currently using a standard car battery this could be the problem.
be ware start saving your pennies 100amp batteries arn't cheap
good luk
fasterdanu is offline   Reply With Quote
Old 05-02-2003, 03:27 PM   #3
rc-zombies's Avatar
first you connect the motor leads to the motor then turn it on..
and the motor should run..after it's on adjust voltage to 4 or 5 volts.
the manual is available on line on the integy website.
Orion motor dyno/checker 85 shipped Mo Denton R/C Items: For Sale/Trade 2 03-19-2008 03:33 AM
Indi Motor Checker clay104 R/C Items: For Sale/Trade 3 07-04-2007 08:15 AM
Motor Dyno/Checker factoryteamryan R/C Items: Wanted to Buy 0 02-17-2005 10:43 PM
Wanted motor dyno/checker adz R/C Items: Wanted to Buy 1 06-13-2004 08:00 AM
CS Motor Checker Dyno and LAPTOP!!! rayhuang R/C Items: For Sale/Trade 19 02-16-2004 01:17 PM
SEO by vBSEO 3.5.0
