Old 07-30-2007, 10:09 AM   #1
RED-LINE M03's Avatar
Trader Rating: 127 (100%+)
Default Processing and Responce Times
I was wanting to know if you can take an older radio like the Ko Propo Mars which has been probaly on the market from the late 90's and install a Spectrum Pro series to bring the Mars up to current radio processing speeds.
Is the Tx module the CPU processor or the brains of the controller or is there more processing going on inside the controller?
I've always liked the older Ko Propo Mars radios and was just wondering with installing the Spectrum Pro series will it bring it up to speed with todays other modern radios proceesing and responce times.
Many Thanks......
RED-LINE M03 is offline   Reply With Quote
Old 07-30-2007, 04:38 PM   #2
CarlosG.'s Avatar
Send a message via Yahoo to CarlosG.
As far as I can tell, the Tx module is only the transmitting part. The CPU(brain) is actually in the pistol grip controller and not in the module. Also putting a Faster Spektrum system on the Mars- R is not a problem, just that the lateincey response will be a tad bit slow, but hardly noticeable.
CarlosG. is offline   Reply With Quote
Old 07-30-2007, 10:58 PM   #3
QuickRC's Avatar
Assuming your Mars is FM or PCM adding a spectrum will actually DECREASE response time. You will have the benefit of no frequency conflicts and such but being used to that you may not be happy with the slight lag the Spektrum will have. I use an older Futaba 3PJ PCM/FM radio and if I use somebody's Spektrum radio the lag is noticeable to me - but no to them.
Really, ,the processing speed of the functions of the radio - such as expo, rates, etc, etc - are built in. The other factor of processing speed is in the Spektrum module and that has no relationship to the radios functions with regard to speed.
QuickRC is offline   Reply With Quote
KO Propo 2344 Didgital servo .13 sec responce 180oz torque DustinR R/C Items: For Sale/Trade 7 03-26-2008 06:59 AM
WTB lst for fun times duce duce R/C Items: Wanted to Buy 4 01-30-2007 09:13 AM
BIG REG GET THE RESPONCE I AM AFTER FROM THE MODERATORS Big Reg Australian Racing 1 08-28-2006 02:17 AM
how many times a day? kh15 Electric On-Road 2 08-10-2004 09:04 AM
run times h22ah Electric On-Road 13 04-15-2004 04:21 PM
SEO by vBSEO 3.5.0
