Battery Pack wont take a charge
I have three sets off batteries. Two are trinity that i bought a few years back. Have not charged them in a while. One pack will charge, the other will not register on my charger.
I have the same problem with my trinity nitro pack. Been sitting, when i connect it the charger will not givve me the ready light to beging charging.
Are these packs shot, they only have one season of racing on them.
How can i fix this??
If they have been sitting long enough they are toast. They most likely have self discharged to the point that they are useless.
i cant even get them to begin to charge. When i batteries get hooked up to my charger, it gives a red flashing light to show they are ready to start charging. I cant even get that
try using a different charger, wall chargers works perfectly on this particular case, after putting in charge and finally your regular charger identifies the batteries,,, cycle them a few times and that should wake them up.
like he said a couple of posts before, just pump some juice into it with a power supply. set it to a voltage of n x 1.5 (where in is the number of cells) as Ni-mh's peak at 1.5 volts.
