Any significant differences between $$$ peak charger and regular peak charger?
I have a Auto-cutoff, adjustable 1A-5A peak charger that is 10 years old. The charger has never let me down.
Just wondering if upgrading to ultra expensive charger will make any difference in the performance and speed? I am a serious racer who attends club races regularly. I am trying to avoid spending $$ on useless items though.
BTW, I only use NI-CD cells.
That would probably not give you any extra speed, but getting something like a T35 will allow you to have alot of cool features, like lathe run, battery discharge...
does your existing charger work???if so keep it upgrade to a new charger when you have the $$
My charger cost me $45 ten years ago(bought from HK)
It has 110/220V, DC, 1A to 5A charging, auto-cutoff, trickle charge, (SCE-SC-SCR)selectable charging, and (Hi, Lo) cut off.
It never fails.
It never fails.
A new charger may help keep your batteries to last longer, but I don't think it would give you more voltage. If you already have apower source, check out the tekin, BC112A?
No, they're back up and running
Originally posted by Taz_S
I still will not go with them because they have no cut off threshold like the Millimum dose
P0- 0.03v or less
P1- 0.03-0.04v
P2- 0.06-0.08v
To all intents and purposes the three profiles are quite adequate for charging NiCd and Nimh batteries.
How about "I wouldn't go with Tekin until they get back on track and can supply product and REPAIRS in a timely fashion...and can answer the phone." - sorry, but I'm just one of many unsatisfied Tekin customers...
Bottom line is a delta peak charger from 10 years ago will still sense the delta peak now.
I had a G-10, it burnt up first of december, I didnt get it until January, but that was no prob because it was over the holidays..
guys, can u help me here? i'm thinking between these two chargers novak's millenium and integy's 16X5 charger. which one would you prefer, and why?
or may be suggest another brand but the price must not be far from those
integy 16x5
i've been eying that 16x5 also, i just started a tread on it to, i think the thing ie great, i've gotten good reviews on it for other message boards. a guy i race with has a 16x3pro2.5 and he loves it, hasn't had a problem. i just don't see how you can beat a fully programable charger, 20A discharger, 14A power supply all in one package for $230, the power supply is enough to run 2 16x5's at once, so i'm figuring a way to run a lathe off it as well. if you do go with the millenium the new one is the Pro, it has a built in pitwizard, but no 20A discharge + you're gonna need a DC power supply if you don't have one! the 16X5 does this VESC charge said to lower IR on cells and increase voltage (we'll see) it'll also cycle packs up to 9 time consecutivly. you can set delays after charge and discharge funtions to let packs cool.
