BMI's DB12R
#1396
R/C Tech Elite Member
If somehow I'm descent with the 1/12 scale off the bat, we'll have to figure out a way to get into a 1/12 class at IIC.
#1397
PM to Jason.
#1398
I want to let all of you guys know, we are cutting a wide range of thicknesses of flex plates right now and every set we have is measured with a micrometer and seperated in .002 increments. If you feel that you want to try certain thicknesses, please feel free to let me know. I have them seperated and chances are i have the set you are looking for. I want to have the option open for you. They range from .061-.073 and we have about 5 variations in small increments to allow you to really fine tune.
This is for that little change you may feel will work for your track. If any of you have any questions on them feel free to ask away.
#1399
0.061-0.073 with 0.002 increment... that's 7 options IMHO too much options too chose from You can spend the whole day just switching the plates and looking for the only RIGHT one. I think 3 options would be already enough - soft/medium/hard.
#1400
UGA,
95% of the time people will use the .073's, they are good, having the other plates as an option is perfect for the racers that like it. What I am saying is you can tune the car just fine with the stock plates...
Racers are a curious bunch, have 2 plates.. not enough.. have 7 ... too many...
#1401
UGA,
95% of the time people will use the .073's, they are good, have the other plates as an option is perfect fo the racers that like it. What I am saying is you can tune the car just fine with the stock plates...
you should be worrying about getting your stuff ready for this weekend
#1402
Good point Tim You convinced me
#1404
Jason, what's the effect of lowering the 'tweak' screws (to stiffen the plates) compared to changing the thickness of the plate?
If I used thin plates with the screws down, would I get the same roll stiffness and handling as a thick plate with the screws up, for example?
Thanks.
Thanks.
#1405
Can someone post Cheston's Stock setup for the DB12R? The link on the BMI website isn't working.
Thanks,
Thanks,
#1406
servo munting height
Jason/ Adrian-
What's the effect of mounting the servo in the upper holes of the servo mount? I'd gues that it'd have an effect on bump and ackerman.
Also, have you guys found that you prefer to mount the servo in the forward holes on the chassis with the steering rods behind the servo saver. I'd presume that this would aid in weight tranfer and help provide more off power as well as on power steering.
Thanks,
E
Thanks,
E
#1407
Thanks.
Thanks.
Lowering the screws will stiffen the plates some but the biggest difference is that it makes the side plate more progressive. For instance, if your car is pushing on high speed corners but the turn in is fine, if you use the screws, it will add a little more high speed steering from the increased load on the front tire as the roll of the car increases. It is a nice tuning option. For the most part i have not needed them but some have and said it was real good. They are mostly used with the thinner plates.
#1408
Jason/ Adrian-
Thanks,
E
Thanks,
E
The forward and rearward holes are for if you want to run the ballstuds on the front or rear of the servo saver. We use this adjustment for your desired static balance that you are looking for. Forward will give a little more weight over the nose and allow for more on power steering and tone down the initial steering.
#1409
What size are the Jaco Prizm tires out of the box? What size do you true them to?
