Old 09-13-2007, 01:03 PM   #1366
Trader Rating: 14 (100%+)
Does anyone have a pic of a DB12R with a GTB system installed with the heatsink? I just bought a GTB w/lipo cutoff for my 1/10 car with a lipo pack (great idea eh? hehe). I have tried taking heatsink off and replacing it with an aluminium plate but after lifting the heaksink off, theres blue thermal paste/goo under it. I didnt want to mess with it.
Speedpassion : Speedpower : East Coast Bodies
thunderbt3 is offline   Reply With Quote
Old 09-13-2007, 01:07 PM   #1367
Nevermind, im a retard. I shouldve used the search function first
Old 09-13-2007, 01:09 PM   #1368
Originally Posted by joey View Post
heres a shot of mine with the gtb installed..
its not the nicest install but it worked good and didnt have any problems with wires being in the way.
Were there any problems with the body contacting the heatsink?
Old 09-13-2007, 01:54 PM   #1369
BSchorr's Avatar
Trader Rating: 92 (100%+)
Send a message via AIM to BSchorr Send a message via Yahoo to BSchorr Send a message via Skype™ to BSchorr
Ill be running a GTB 4-cell/13.5 system in my DB12R, Ill take some sweet pics when i get it all ready to run.
TLR ~ MaClan ~ Hobbywing ~ Futaba ~ Proline ~ Werks Racing ~ Genesis R/C Products ~ Mr. Scrubbles ~ First Premier Satellites
BSchorr is offline   Reply With Quote
Old 09-13-2007, 02:26 PM   #1370
rcgen's Avatar
Originally Posted by BullFrog View Post
Adrian are you bringing both the 1/12th and 1/10th cars to the state race this weekend?
I'll be running my 1/12. Your more than welcome to check my car out.
rcgen is offline   Reply With Quote
Old 09-13-2007, 02:31 PM   #1371
protc3's Avatar
Originally Posted by EricF View Post
Jason or Adrian,
does having the flex plate screw affect the flex of the plate or does it only have an affect if its touching the cahssis?
Thanks,
E
Having the screw in but not touching will not change the flex of the flex plate. If you touch it to the chassis it will increase the tension some and will also make the flex plate more progressive
Jason Breiner
BMI Racing
Team Associated
J Concepts
protc3 is offline   Reply With Quote
Old 09-13-2007, 02:32 PM   #1372
protc3's Avatar
So they are going to show up at the state race?
Sorry bill, we will not be attending the state race. I wish i was because that track is awesome
Jason Breiner
BMI Racing
Team Associated
J Concepts
Old 09-13-2007, 02:37 PM   #1373
protc3's Avatar
Originally Posted by VVS1 View Post
Does BMI ship to oversea?? I am in HK
Yes, We ship worldwide.
Jason Breiner
BMI Racing
Team Associated
J Concepts
Old 09-13-2007, 02:39 PM   #1374
protc3's Avatar
Originally Posted by radio_car_racer View Post
Jason,
Ran the car on Tuesday night after Sunday’s race when I ran the FF’07 DB12R not ready.
This was done after the carpet had aired for 2 days and was the same layout.
Only had two runs using same motor (unskimmed) & tyre type and,
Single lap faster by 1.17s
Average lap down by 1.057s
Unbelievable the way the car corners with speed.
Only place I seemed to struggle was in the switch backs (left/right/left) were the car was to responsive. Maybe addy & or servo KO949. (Usually run a Sanwa 141)
Tried the olive spring to gain a bit more rear end.
Car seemed to be skipping a lot under power on the rear.
Body: Hot Bodies Ferrari (used as I like it and didn’t have a Parma ready)
Tire Compounds: BRM Purple/Grey = f 44mm r52mm
CS High Grip Tyre Additive : Full front & Rear (like to do full front to help keep tyre wear even)
Reactive Caster: 10* Block
Caster: Middle
Camber: set to run foams square
Ride Height: 3.5mm
Toe: zero
Front Track: no shims on axles
Front Spring: .020”
Front Preload/Droop: No Preload/very little
King Pin Damping: none (don’t like to do it)
Servo Mounting: Angled
Shock Length/Pod Droop: 2.6” (66mm)/.060 (1.5mm)
Shock Angle: Med IRS ball stud on AE Ant-Shock mount
Shock Spring: AE gold / AE Olive
Shock Oil: 35wt
Side Damper Oil: 100wt shock oil (no heavier oils)
Flex Plates: .070”
Flex plate preload screws: Not installed
Rear Body Mounts: To the rear
Rear Track: 172mm
Jason's been back to me and I need to try thicker lube in damper tubes. Going to use corally medium damper fluid as suggested by Jason.
see attachment
top heat = drivers best heat that made the A final & won the event
DB12R = 2nd run with car
heat 4 = best run with FF'07
Track Layout
That is really awesome buddy. I'm glad to hear that you are comfortable with the car in such a short amount of time. If i can help you in any way, please feel free to ask.
Jason Breiner
BMI Racing
Team Associated
J Concepts
Old 09-13-2007, 03:29 PM   #1375
Randy Caster's Avatar
Trader Rating: 46 (100%+)
Dang I was wondering when we were going to see a Jason or Adrian reply, normally you get a reply within 5 mins of the post!
Old 09-13-2007, 03:42 PM   #1376
AdrianM's Avatar
I shipped my car on Friday. You will get it tomorrow
Adrian Martinez
Old 09-13-2007, 04:13 PM   #1377
I've been rushing home the past couple days to see if it showed up, cant wait to check it out firsthand!
Old 09-13-2007, 04:56 PM   #1378
protc3's Avatar
When you get the car randy, you need to talk to it nicely and make it feel nice. That car is in shock from how bad i spanked it. It needs to be shown that it can be driven fast.
Jason Breiner
BMI Racing
Team Associated
J Concepts
Old 09-13-2007, 05:08 PM   #1379
AdrianM's Avatar
Hmm, I blew the rotor on my 5.5 before the main and with an 8.5 (5800) I managed to make an inside pass on you in the infield and drive away for a few laps. Then you got yourself straightend out, started making fast laps and reeled me in. Even then your fast lap was a 11.0 (w/ a 5.5) and mine was a 11.1 (w/ a 8.5).
All I can say is....REMATCH in 2 weeks sucka!
Adrian Martinez
Old 09-13-2007, 05:16 PM   #1380
protc3's Avatar
where was i when this happened??? I have the lap sheet and it says you did an 11.2 for fast lap and it said i was 1st from lap 1. It also showed me at a 41 8:00 and you at a 40 8:02. PUNK!!!
Jason Breiner
BMI Racing
Team Associated
J Concepts
NEW IN BOX BMI DB12R bigb11 R/C Items: For Sale/Trade 47 10-09-2008 04:36 PM
-BMI DB12R- joey R/C Items: For Sale/Trade 11 05-18-2008 09:25 PM
BMI DB12R wallstreet R/C Items: For Sale/Trade 17 02-15-2008 05:04 PM
BMI DB12R D-Bizzle R/C Items: For Sale/Trade 2 12-21-2007 03:48 PM
WTB BMI DB12R chris moore R/C Items: Wanted to Buy 8 06-29-2007 06:25 PM
