Old 09-12-2007, 05:06 PM   #1351
protc3's Avatar
Originally Posted by RCSteve93 View Post
Was something different in the first production run cause mine came with shims and non-flanged bearings.
No,the first run of cars went with non flanged bearings. I wasnt aware of the Prism wheels using flanged until i got them in. Being that i am offering the Prism's with the car, i had to change the kits to flanged bearings. I had to eat hundreds of bearings everything else is identicle.
Jason Breiner
BMI Racing
Team Associated
J Concepts
protc3 is offline   Reply With Quote
Old 09-12-2007, 05:08 PM   #1352
protc3's Avatar
Originally Posted by joey View Post
hey jason i got my box of foams the other day thanks for the fast shipping..
i also got the fiberglass battery adjuster in yesterday..
thanks again i should be placing another order for foams in a few weeks
No problem buddy. Thanks.
Jason Breiner
BMI Racing
Team Associated
J Concepts
Old 09-12-2007, 05:16 PM   #1353
Nova F1 Racer's Avatar
R/C Tech Charter Subscriber
Originally Posted by AdrianM View Post
You are lucky she does a great job...if you had to fire her it could get ugly...lol!
Not really, she could go work for any RC company and double her salary!!!!! She remembers everything about all my orders...
Oh oh.... Mental note.. Don't EVER let her talk to my wife cuz the first thing the lovely Donna would ask is about what I ordered and how much everything was....
This is DICK!!! And you're NOT!
RC Tech member #11
Aussie Rules Footy, Brisbane LIONS!!
[url]http://www.pitter-pat.com/[/url] for pet care needs in Northern Virginia
Nova F1 Racer is offline   Reply With Quote
Old 09-12-2007, 05:18 PM   #1354
Originally Posted by protc3 View Post
They are going into production. I have had a couple guys say they broke there locators. I see this as something that needed to be addressed so i did so. I made them after the 2nd complaint. They will be put on the website immediately and we are also going to make them standard with the car now. We want this car to be a great experience for everyone. If we find anything that seems to be a trouble spot,we will address that problem immediately.
Now wait a minute... I didn't complain about that... I was in shock that it was the only thing that broke.... I'll have to add that to my next order....
RC Tech member #11
Old 09-12-2007, 05:22 PM   #1355
protc3's Avatar
Jason Breiner
BMI Racing
Team Associated
J Concepts
Old 09-12-2007, 08:52 PM   #1356
RichChang's Avatar
It went out today buddy
Sweet!! Thanks, Jason. My wedding anniversary is on the 19th... I hope it doesn't arrive on that day. LOL!
-Rich
RichChang is offline   Reply With Quote
Old 09-12-2007, 09:26 PM   #1357
Randy Caster's Avatar
Trader Rating: 46 (100%+)
mmm.. the 16th is coming soon, cant wait!
Old 09-12-2007, 10:25 PM   #1358
Originally Posted by Chemical X View Post
I'm almost ready to go with my DB12R, however, I need some advice on tires for carpet tracks.
I'm new to 1/12th scale and will be running mostly 19T and some Stock depending on the track I race at. The tracks in my area all use Jack the Gripper and do not allow Paragon.
That's all we run in Europe. We use grey rear/purple front in low grip, and grey rear/magenta front in high grip. If you prefer, use pink rear/purple front, and in exceptionally high grip pink rear/magenta front.
The other thing to try is 5deg blocks - this is the setting the majority use here on Jack. It reduces the tendency for the car to 'grab' off-power when using Jack. HTH
SlowerOne is offline   Reply With Quote
Old 09-13-2007, 05:13 AM   #1359
Adrian are you bringing both the 1/12th and 1/10th cars to the state race this weekend?
Team Epic/Trinity -Michael Bruce Hobbies-Team CRC ,Kimbrough Products and GForce.
WGT-R, GT Racing USA (17.5 foam), Formula 1 and Home Track is 386 RaceWay,ROAR #7540.
BullFrog is offline   Reply With Quote
Old 09-13-2007, 05:49 AM   #1360
radio_car_racer's Avatar
Thumbs up
Jason,
Ran the car on Tuesday night after Sunday’s race when I ran the FF’07 DB12R not ready.
This was done after the carpet had aired for 2 days and was the same layout.
Only had two runs using same motor (unskimmed) & tyre type and,
Single lap faster by 1.17s
Average lap down by 1.057s
Unbelievable the way the car corners with speed.
Only place I seemed to struggle was in the switch backs (left/right/left) were the car was to responsive. Maybe addy & or servo KO949. (Usually run a Sanwa 141)
Tried the olive spring to gain a bit more rear end.
Car seemed to be skipping a lot under power on the rear.
Body: Hot Bodies Ferrari (used as I like it and didn’t have a Parma ready)
Tire Compounds: BRM Purple/Grey = f 44mm r52mm
CS High Grip Tyre Additive : Full front & Rear (like to do full front to help keep tyre wear even)
Reactive Caster: 10* Block
Caster: Middle
Camber: set to run foams square
Ride Height: 3.5mm
Toe: zero
Front Track: no shims on axles
Front Spring: .020”
Front Preload/Droop: No Preload/very little
King Pin Damping: none (don’t like to do it)
Servo Mounting: Angled
Shock Length/Pod Droop: 2.6” (66mm)/.060 (1.5mm)
Shock Angle: Med IRS ball stud on AE Ant-Shock mount
Shock Spring: AE gold / AE Olive
Shock Oil: 35wt
Side Damper Oil: 100wt shock oil (no heavier oils)
Flex Plates: .070”
Flex plate preload screws: Not installed
Rear Body Mounts: To the rear
Rear Track: 172mm
Jason's been back to me and I need to try thicker lube in damper tubes. Going to use corally medium damper fluid as suggested by Jason.
see attachment
top heat = drivers best heat that made the A final & won the event
DB12R = 2nd run with car
heat 4 = best run with FF'07
Track Layout
radio_car_racer is offline   Reply With Quote
Old 09-13-2007, 06:17 AM   #1361
TimPotter's Avatar
Trader Rating: 14 (100%+)
Send a message via AIM to TimPotter
Bill, that would mean he is racing.... So I doubt it . Then again, Adrain was the guy that drove 4 hours to deliver tires for a state race......
Clean Title & Escrow|p3|TRF|Tamiya|SerpentAmerica|FSEARA|Team Butter|RC 3|Munno |RCTECH #29|EAMotorsports|BMI|Novak|SpeedPassion|RadioPost
TimPotter is offline   Reply With Quote
Old 09-13-2007, 06:29 AM   #1362
Default order from hk
Does BMI ship to oversea?? I am in HK
VVS1 is offline   Reply With Quote
Old 09-13-2007, 06:34 AM   #1363
Uga
Uga's Avatar
Yes, I got it even to Latvia
Uga is offline   Reply With Quote
Old 09-13-2007, 09:58 AM   #1364
So they are going to show up at the state race?
Old 09-13-2007, 12:34 PM   #1365
EricF's Avatar
Jason or Adrian,
does having the flex plate screw affect the flex of the plate or does it only have an affect if its touching the cahssis?
Thanks,
E
EricF is offline   Reply With Quote
NEW IN BOX BMI DB12R bigb11 R/C Items: For Sale/Trade 47 10-09-2008 04:36 PM
-BMI DB12R- joey R/C Items: For Sale/Trade 11 05-18-2008 09:25 PM
BMI DB12R wallstreet R/C Items: For Sale/Trade 17 02-15-2008 05:04 PM
BMI DB12R D-Bizzle R/C Items: For Sale/Trade 2 12-21-2007 03:48 PM
WTB BMI DB12R chris moore R/C Items: Wanted to Buy 8 06-29-2007 06:25 PM
