Old 09-10-2007, 08:50 PM   #1276
darnold's Avatar
I really liked my car from the main through Sunday practice. I tried so many changes and different combo's that I sometimes felt like I was in the twilight zone.
The track was very bumpy for 12th scales and we were running Jack so it took a little time for the grip to come up. I went there with last seasons batteries which I had tested a couple of days before the race and I only had 4 packs that were between 360 - 380 sec/35A, everything else was lower.
Mr. Power Push Carruba was a real gentleman and loaned me some of his practice packs to run with, but in all honesty I simply wasn't focused on gearing or trying to make time. Regardless, I want to offer my sincere thanks to Tony and Vicky for all of their generosity.
I went to this race because I viewed it as an F1 pre-season test date and I am extremely glad that I went. Wayne Gerber Jr., Rob King, Mike Blackstock and "Goop" were all extremely helpful, thanks guys, I really appreciated it and definitely needed it.
Mike Blackstock thought the car looked good by the main but needed some more adjustment to make it easier to drive. I stayed until 1 am asking him questions and testing stuff to get closer to this goal.
In the end I actually wound up running the setup that Adrian M posted for carpet. Man, I just knew I was never going to live that one down.
Again, thanks everyone for your help. I'm just trying to learn and get better.
darnold is offline   Reply With Quote
Old 09-10-2007, 09:04 PM   #1277
BlackedOutREVO's Avatar
Trader Rating: 67 (100%+)
Is there a foam bumper that fits this car?
Or do I have to hack one up?
R1 Wurks/Awesomatix USA/Roche USA/Protoform/Solaris/Mo Speed/Speedworld Raceway
BlackedOutREVO is offline   Reply With Quote
Old 09-10-2007, 09:07 PM   #1278
BSchorr's Avatar
Trader Rating: 92 (100%+)
Send a message via AIM to BSchorr Send a message via Yahoo to BSchorr Send a message via Skype™ to BSchorr
I orderd the Parma bumpter for mine, but i was told the DB12 posts in the front where alittle wide. So I may be looking for another bumper to. I have to have everything perfect on my rig!
(Also the Base Setup on the site still does not work, just wanted to throw that out)
TLR ~ MaClan ~ Hobbywing ~ Futaba ~ Proline ~ Werks Racing ~ Genesis R/C Products ~ Mr. Scrubbles ~ First Premier Satellites
BSchorr is offline   Reply With Quote
Old 09-10-2007, 09:48 PM   #1279
AdrianM's Avatar
The one from pdubracing.com fits...fyi, they are in the middle of getting their new website up.
Adrian Martinez
Old 09-10-2007, 09:53 PM   #1280
Which P-dub one?
Isnt there more then one?
Old 09-10-2007, 10:22 PM   #1281
ttso's Avatar
Originally Posted by Mr. Shookie View Post
Here is mine, it looks a little different now but the same concept.
BMI's DB12R
Hope that helps,
-Shookie <><
What's the white stuff on spur? diff cover? any link where to get it?
Thanks.
ttso is offline   Reply With Quote
Old 09-10-2007, 11:12 PM   #1282
Thanks.
Kimbrough diff cover. You have to use a spur gear with a ring (Kimbrough, PRS) to snap those on.
Diff Covers
Sydewynder is offline   Reply With Quote
Old 09-11-2007, 12:22 AM   #1283
ttso's Avatar
Got it. Thanks..
Old 09-11-2007, 05:13 AM   #1284
have you got a copy or remember the post #?
Irri Tant is offline   Reply With Quote
Old 09-11-2007, 10:08 AM   #1285
darnold's Avatar
From Adrian M. on Page 20:
Here it is:
Body: Speed 8 Parma
Wheel Diameter: Asphalt 1.75F-1.85R, Carpet 1.70F-1.75R on Jaco, CRC, BSR,Parma big rims
Tire Compounds: Double Pink F&R
Caster: Middle
Reactive Caster: 10* Block
Camber: 1.5*
Ride Height: 3.5mm
Toe: .5mm out
Front Track: Narrow as possible on asphalt, .030 of shims on each axle for carpet
Front Spring: .020
Front Preload/Droop: No Preload/very little
King Pin Damping: 5000Wt
Servo Mounting: Angled
Shock Length/Pod Droop: 2.6 (66mm)/.060 (1.5mm)
Shock Angle: Med IRS ball stud on AE Ant-Shock mount
Shock Spring: AE gold
Shock Oil: 35wt
Side Damper Oil: 5000wt
Flex Plates: .070
Flex plate preload screws: Not installed
Rear Body Mounts: To the rear
Rear Track: 172mm
The starting setup is pretty much the same on carpet and asphalt. All the hardware you need to do this is in the kit.
Old 09-11-2007, 03:41 PM   #1286
protc3's Avatar
That setup works extremely well. In 19 turn on carpet we went to .018 front springs when the bite came up. Other than that the setup was the same. It worked excellent
Jason Breiner
BMI Racing
Team Associated
J Concepts
protc3 is offline   Reply With Quote
Old 09-11-2007, 03:49 PM   #1287
haagar's Avatar
Cars almost ready to go. Just waiting on the transponders to get back from MRT. A track to run at would be nice too. Going to have to miss next week at the track that runs every other week and the track that runs every week is still running off road outdoors
haagar is offline   Reply With Quote
Old 09-11-2007, 03:52 PM   #1288
protc3's Avatar
Clean layout dude. Nicely done. Which center spring is that and what is the spring rate?
Jason Breiner
BMI Racing
Team Associated
J Concepts
Old 09-11-2007, 03:53 PM   #1289
RCSteve93's Avatar
I use the Slapmaster one and it is fine. It just is a little small, so you need to slice a 2mm long slice in it so the foam will give and extend for the body posts.
rm -rf /windows
RCSteve93 is offline   Reply With Quote
Old 09-11-2007, 04:01 PM   #1290
haagar's Avatar
Thanks. It is a Windtunnel black which is 12#. It should be really close to the AE gold.
NEW IN BOX BMI DB12R bigb11 R/C Items: For Sale/Trade 47 10-09-2008 04:36 PM
-BMI DB12R- joey R/C Items: For Sale/Trade 11 05-18-2008 09:25 PM
BMI DB12R wallstreet R/C Items: For Sale/Trade 17 02-15-2008 05:04 PM
BMI DB12R D-Bizzle R/C Items: For Sale/Trade 2 12-21-2007 03:48 PM
WTB BMI DB12R chris moore R/C Items: Wanted to Buy 8 06-29-2007 06:25 PM
