Old 06-22-2011, 09:59 AM   #8626
20 SMOKE's Avatar
Trader Rating: 101 (100%+)
i think something came loose up stairs when you broke you leg and the DR missed it
Jamie W
*Team Tekin*TLR Racing*DE Racing*92 Zero Design*AKA*DDHRC*
20 SMOKE is offline   Reply With Quote
Old 06-22-2011, 10:01 AM   #8627
Super Moderator
Marcos.J's Avatar
Trader Rating: 150 (100%+)
might have i know my leg is still has the screws in it so its not it lol
Old 06-22-2011, 01:22 PM   #8628
dkrall's Avatar
Hey guys,
Slight problem here. I was putting together my DB12RR, (I'm using a Speed Passion Stock Club ESC, a Spektrum SR300, a Spektrum Dual Regulator, and an Rx pack, as well as a Reedy 1s battery) and whenever I turn on the switch for the receiver pack, everything turns on and the Rx pack powers the whole vehicle. Not sure if this is due to a wiring error caused by me, or if something is wrong with one of the electronics. Leaning towards an error by me. Has anyone ran into this before or know how to fix it?
Thanks in advance.
The only reason people get lost in thought is because it's unfamiliar territory.
dkrall is offline   Reply With Quote
Old 06-22-2011, 01:40 PM   #8629
Most of the new ESCs today will sense power coming from the receiver and turn themselves on. The receiver pack will power the servo, the receiver, and the ESC. So long as it isn't powering the motor you probably have it wired right.
Old 06-22-2011, 01:41 PM   #8630
20 SMOKE's Avatar
a rx pack can turn on the esc,some of the older ones that do not have a 1s application you cannot turn on the esc as you will fry it
Jamie W
Old 06-22-2011, 03:12 PM   #8631
dkrall's Avatar
Even with the main pack plugged in though, there was barely any power going to the motor, which makes me think that it's running off the Rx pack still
Old 06-22-2011, 04:23 PM   #8632
20 SMOKE's Avatar
it sounds like it is only running off the rx pack i would ask this in the SP thread
Jamie W
Old 06-22-2011, 04:38 PM   #8633
Do you have the RX pack wired to the ESC or plugged directly into the RX?
Old 06-22-2011, 06:06 PM   #8634
dkrall's Avatar
Its plugged into the Spektrum Dual Regulator, which is connected into the Rx
Old 06-22-2011, 06:29 PM   #8635
Sounds right then...It couldn't be powering the motor through the RX. Remember your only putting 3.7v to the motor so it isn't going to sound like a rocket.
Old 06-22-2011, 06:53 PM   #8636
dkrall's Avatar
This was REALLY slow though. This is my first 1/12 scale, but I'm pretty sure that it shouldn't be that slow.
Also, on the 1/12 forum, Lonny said that the Rx pack should go directly into the Rx, so I don't know if that may be a problem...
Old 06-22-2011, 06:58 PM   #8637
20 SMOKE's Avatar
its not pluged in the rx,it should be
Jamie W
Old 06-22-2011, 07:01 PM   #8638
dkrall's Avatar
I have it plugged in to the regulator, which is plugged into the Rx. Is that wrong?
Old 06-22-2011, 07:06 PM   #8639
20 SMOKE's Avatar
thats right,i would say there is something with the esc,there has to be a setting
Jamie W
Old 06-22-2011, 07:06 PM   #8640
avs
avs's Avatar
Originally Posted by dkrall View Post
Hey guys,
Thanks in advance.
you don't indicate what the receiver pack is lipo or nimh? it matters
you don't indicate what the instructions for speedpassion say. some ESC's can run off the receiver pack, and others need to have the 'red' wire lifted from the plug.
if the motor is turning VERY slowly it is suspicious that the ESC may be powered by the receiver pack.
rtfm
Tony Shimko
avs is offline   Reply With Quote
NEW IN BOX BMI DB12R bigb11 R/C Items: For Sale/Trade 47 10-09-2008 04:36 PM
-BMI DB12R- joey R/C Items: For Sale/Trade 11 05-18-2008 09:25 PM
BMI DB12R wallstreet R/C Items: For Sale/Trade 17 02-15-2008 05:04 PM
BMI DB12R D-Bizzle R/C Items: For Sale/Trade 2 12-21-2007 03:48 PM
WTB BMI DB12R chris moore R/C Items: Wanted to Buy 8 06-29-2007 06:25 PM
