Old 09-25-2010, 12:06 PM   #8596
JayBee's Avatar
Trader Rating: 31 (100%+)
Originally Posted by The Hawaiian View Post
I'll be running my BD12RR for the first time @ Florida indoor R/C complex this Sunday, and I can't wait...Jason are you running this weekend
Is that the Speed 12B? Looks killer brah.
R C 3 G R A F I X _ F U S I O N . G R A P H I X _ S E A T T L E - R/C - R A C E R S _ E M E R A L D C I T Y R C . C O M
A E - 12R5.2 _ S M - REV8 PRO
JayBee is offline   Reply With Quote
Old 01-15-2011, 10:01 PM   #8597
dkrall's Avatar
Hey guys,
Just got an older DB12, with the conversion kit to make it into the DB12RR. I'm most likely going to be running a Novak GTB and Novak 17.5r, Airtronics servo, and a Reedy 4600mah LiPo.
I'm new to on-road, but have been racing on carpet. Anything I should know about racing this or any parts you guys recommend that I get?
dkrall is offline   Reply With Quote
Old 01-15-2011, 10:08 PM   #8598
Originally Posted by dkrall View Post
Hey guys,
A Tekin RS or RS Pro if your track allows timing advance speed controls, to take full advantage of the Tekin you need the hotwire and a computer to set it up.
Find out what tires people are running at your local track, generally yellow rears and lilac or black fronts are pretty common and a good starting point.
avink007 is offline   Reply With Quote
Old 01-15-2011, 11:02 PM   #8599
chris moore's Avatar
Trader Rating: 85 (99%+)
Hey guys,
If you dont have any I'd recomend the CF hockey sticks, The car is tough and will take a pounding.
Sponsered by:
CMDezigns Paint Works
https://www.facebook.com/pages/CM-Dezigns/259989190822177?ref=hl
chris moore is offline   Reply With Quote
Old 01-19-2011, 05:42 PM   #8600
dkrall's Avatar
Thanks for the input.
Got another question- still need to buy an ESC. I already have a Novak 17.5t brushless motor and would like an ESC with LiPo cut-off.
I would like something that doesn't a whole lot since I am starting out, and have been looking at a Havoc 1s with a low-profile heatsink conversion (can't find height spec for it), as well as a Speed Passion Cirtix Inspire V2.0 (18mm height w/o cooling fan). The SP GT2.0 LPF Brushless ESC is a possibility as well, but I'm not sure if I want to spend that much (although it is 24mm high).
-How much clearance do I have between the chassis and the body?
-Is there anything else that you guys would recommend? (trying not to spend too much)
Thanks again
The only reason people get lost in thought is because it's unfamiliar territory.
Old 01-19-2011, 06:33 PM   #8601
The amount of clearance depends on which body, and how low you mount the body. As to esc recomendations I love the Tekin RS, its not real expensive andyou can just run in blinky mode if you dont want to mess with the boost and timming issues. Plus its real small and fits the DB12R great(see my the pic of mine). I cannot recomend the havoc, I dont own one but have read about many problems. If you want something less expensive the citrix esc/motor combo is around $100 I think. Also if your running 1s you will need a booster or RX pack.
Sponsered by:
Old 01-20-2011, 09:38 AM   #8602
dkrall's Avatar
Thanks Chris,
I think I may end up going with a Speed Passion Cirtix, mainly because they are cheaper (unless I can pick up something locally thats used). Wasn't sure if it would fit or not though.
Old 03-02-2011, 07:18 PM   #8603
Trader Rating: 45 (100%+)
I'm selling a DB12R, here is the link.
BMI DB12r with 2 Fantom 5000 1s lipo's
G the Menace is offline   Reply With Quote
Old 04-05-2011, 07:38 AM   #8604
I'm selling my BMI Copperhead 12 and DB12RR Lipo chassis parts.
http://cgi.ebay.com/BMI-Racing-Coppe...#ht_500wt_1075
Old 05-31-2011, 05:05 PM   #8605
dkrall's Avatar
Hey guys,
Two questions for ya:
-Is there enough room to fit a Spektrum SR300 on its side in one of these cars?
-What is good gearing to run on a track that doesn't have the greatest traction? I'm running a 17.5t motor and I have an assortment of tires, not sure what to run yet. I am just starting on-road though, so speed is the least of my concerns.
Thanks in advance
Old 05-31-2011, 09:13 PM   #8606
LonnyJ1950's Avatar
17.5 guys run roll outs anywhere from 70mm to 100mm, higher will give you less wheel spin on low bite. I would start about 80-85mm and check your motor temp after about 2 min. gear up if it's not too hot. Start with lilac or purple fronts if you have them, and yellow or orange (CRC Gralow) rears. Go softer (double pink or magenta) at the front for more steering if you need it. The receiver might fit if you put it very close to the center of the car. Try it.
Lonny
LonnyJ1950 is offline   Reply With Quote
Old 05-31-2011, 11:13 PM   #8607
Yes you can run the rec on its side but I cannot really see any advantage to this configuration. Lonnie is right on for the gearing and the tires if your running on carpet but the tires will differ abit if your on asphalt. On a side note this car is great on low traction surfaces.
Sponsered by:
Old 06-01-2011, 12:23 AM   #8608
LonnyJ1950's Avatar
True! If you're racing on asphalt you probably want to start with Purple fronts and Pink rears. That is generally the go to set up.
Lonny
Old 06-01-2011, 02:04 PM   #8609
dkrall's Avatar
Thanks for the info guys!
The reason for having to mount the receiver on its side is plainly the fact that I can't afford a micro receiver. My thinking is this- the servo is mounted to the right of the chassis, so I can place an SR300 and a Spektrum regulator behind that, and I can put my SP Stock Club Race ESC on the left side of the chassis, for somewhat even weight distribution. If you guys know of a better way to do this, please let me know haha. Also, what size pinion gear do I need?
Oh, and I live in SWPA, so there aren't any asphalt tracks around here that I'm aware of. I don't think the weather would be too kind to an asphalt track around here anyway. It's usually cloudy with a 65% chance of depression year round here . I live about 2 hours from a a track in Beaver, PA (w/ ozite carpet) and probably about 3 hours from The Gate in Cleveland. I usually race off road carpet at a track called PT Raceway, and it has a low-knit carpet, where I will most likely start running my DB12s.
Old 06-01-2011, 02:48 PM   #8610
I like a 76 or 78 spur so in order to reach the big rollouts of 90 to 100mm you will need pinions around 50ish + or -. If your using a different size spur then the pinion size will differ. Are you running 1s lipo? I have'nt needed the spectrum regulator in yrs; but if your going to use a rec pack then space will still be tight.
Sponsered by:
NEW IN BOX BMI DB12R bigb11 R/C Items: For Sale/Trade 47 10-09-2008 05:36 PM
-BMI DB12R- joey R/C Items: For Sale/Trade 11 05-18-2008 10:25 PM
BMI DB12R wallstreet R/C Items: For Sale/Trade 17 02-15-2008 06:04 PM
BMI DB12R D-Bizzle R/C Items: For Sale/Trade 2 12-21-2007 04:48 PM
WTB BMI DB12R chris moore R/C Items: Wanted to Buy 8 06-29-2007 07:25 PM
SEO by vBSEO 3.5.0
