Old 02-11-2010, 11:42 AM   #8476
Uga
Uga's Avatar
Originally Posted by 2wdrive View Post
Is it possible to have less chassis cutouts? I can't get my electronics and lead to stick well with double sided tape on the DB10RR chassis as there is not much carbon at the back. I drive 2s saddlepack by the way. Any have a good trick to let the electronics stick better?
Just get a better double sided tape I've had no problem with electronics falling off.
-=Xray XB4=-
-=Xray T4=-
-=Schumacher Cougar KF2=-
Racing in Latvia
Uga is offline   Reply With Quote
Old 02-11-2010, 11:46 AM   #8477
TeamButter's Avatar
Send a message via AIM to TeamButter
+1
I use PARMA's pro servo tape. It has great adhesion and when its time to pull it off it comes off in one or two pieces and doesn't disintegrate like other brands/types.
Xray / BMI Racing / KO Propo / Team Epic / Parma-PSE / High Velocity Racing / TeamButter / P3 Graphics / MDI Racing
TeamButter is offline   Reply With Quote
Old 02-11-2010, 01:05 PM   #8478
I have the same problem with servo tape...problem is most LHS's only carry the cheap servo tape.
Old 02-11-2010, 01:15 PM   #8479
EricF's Avatar
Try Target or Walmart for the clear servo tape. If I'm not mistaken it's the same as Parma's.
E
AE 12R5.2 (x2) - TC7 - M05 - M05V2R
People who don't have to wait for the latest item, should not tell those that do, that "It's worth the wait"
EricF is offline   Reply With Quote
Old 02-11-2010, 02:01 PM   #8480
2wdrive's Avatar
thanks, have orderd the parma pro servo tape
2wdrive is offline   Reply With Quote
Old 02-11-2010, 11:12 PM   #8481
Any chance of getting slightly more width out of the front end with the new chassis upgrade?
Maybe something closer to the crc width?
gguertin145 is offline   Reply With Quote
Old 02-12-2010, 03:42 AM   #8482
E
Is it the same as the Loctite double stick tape?
Old 02-12-2010, 11:56 AM   #8483
EricF's Avatar
Not sure, it's been a while since I've needed to buy any, I'm not sure what on the package or even if it came in a package...
E
Old 02-12-2010, 12:13 PM   #8484
This:
http://www.shopatron.com/products/pr...8044/137.0.1.1
The same as this?:
http://loctiteproducts.com/products/...D=45&SubID=185
Looks the same...if so it didn't hold well enough on my DB10R with the electronics in the rear of the car...just too little material there for my small electronics to hold onto. Larger electronics wouldn't have the same problem. I ended up using Shoe Goo.
Old 02-12-2010, 04:45 PM   #8485
avs
avs's Avatar
The Parma stuff has a '3M VHB' label on it. it is nice for more permanent attachments and it comes off clean (in one piece) it is a clear urethane looking tape (not foam)
the indoor/outdoor 2sided tape they sell at home depot also comes off in one piece, but it doesn't hold on as well, but its cheap. its a grey colored foam.
Tony Shimko
avs is offline   Reply With Quote
Old 02-13-2010, 03:35 AM   #8486
radio_car_racer's Avatar
I cut a lexan tray to fit in the rear, then mounted electronics to that.
I use this tape.
http://www.maplin.co.uk/Module.aspx?...33766&T=Module
radio_car_racer is offline   Reply With Quote
Old 02-15-2010, 06:47 AM   #8487
fpart's Avatar
Trader Rating: 38 (100%+)
Send a message via Skype™ to fpart
Whats the availability date for the new car?
teamYokomo.com teamTrinity.com Sweepracingusa.com
スクービーは私のヒーローです!
Why is Scooby so slow, you might ask?
fpart is offline   Reply With Quote
Old 02-15-2010, 12:13 PM   #8488
Trader Rating: 43 (100%+)
Jason, I need a new foam bumper. Neither you or Stormer seem to have them. Any idea when they'll be back in stock?
biz77 is offline   Reply With Quote
Old 02-15-2010, 12:58 PM   #8489
protc3's Avatar
I do have 1/12th foam bumpers in stock. My website inventory must be screwed up. I will fix it up today.
As for the new car, i am shooting for a release in 2-3 weeks. The parts are being run off now. I need to revamp the instruction manual and box labels and we should be good to go.
Jason Breiner
BMI Racing
Team Associated
J Concepts
protc3 is offline   Reply With Quote
Old 02-16-2010, 03:53 AM   #8490
V12
V12's Avatar
Originally Posted by TeamButter View Post
Hey guys/gals,
I've received several PM's asking what the setup was on my 12th at the Birds so I figured I would post it here.. I took the Format from one of the PM's I received. If anyone has any questions please feel free to ask on here or PM me and I will get to them ASAP.
Thanks,
Butter
Front:
.20 AE springs (shim kingpin for equal sag L and R....approx 0.5mm
0 toe
lilac or black if high trac.(Lilac had more steering using Sticky Fingers)
3.5mm
camber 1Deg
Rear:
3.5mm
#4 Red Shur lube in tubes
45 wt shock oil with piston holes drilled out.
gold spring
shock/antenna mount all the way back.
.5mm droop
Thin Prototype(Sorry guys!) cf flex plates w/no tweak screws.
Orange tires
battery in middle.
Body:Parma EE1
Tire Size: Front 1.63" (Sidewalls glued) Rear 1.68"
what are orange tires? donīt know these.
V12 is offline   Reply With Quote
NEW IN BOX BMI DB12R bigb11 R/C Items: For Sale/Trade 47 10-09-2008 05:36 PM
-BMI DB12R- joey R/C Items: For Sale/Trade 11 05-18-2008 10:25 PM
BMI DB12R wallstreet R/C Items: For Sale/Trade 17 02-15-2008 06:04 PM
BMI DB12R D-Bizzle R/C Items: For Sale/Trade 2 12-21-2007 04:48 PM
WTB BMI DB12R chris moore R/C Items: Wanted to Buy 8 06-29-2007 07:25 PM
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
SEO by vBSEO 3.5.0
