Old 02-01-2010, 08:51 AM   #8341
protc3's Avatar
Its not pink guys.lol Pics do look that way though. It is actually purple. The car is actually lighter than the old car. We went away from the retention belt. The outer pivot location is wider and swings a larger arc. The flex plates are now straight and mount underneath the pivot housing which keeps it at the centerline of the pivot ball and reinforces the housing to eliminate breakage. The pivot points were moved forward over the center pivot mounting location to reduce pod angle change as the suspension compresses. You get more of a lifting action instead of an abrupt pod angle change that you get normally. This smoothes the car out through sweeping and fast corners. There is no flex in the pivot housings now and therefor you get absolutely no forced rear steer under load. The chassis is much more rigid than the older on and allows you to tune your car with suspension. We had absolutely no problem with push in the high bite conditions which has always seemed to be a complaint among elite drivers. We actually had to reduce steering as the car had too much. Overall, the car proved to be much more free and rotate on a dime. It stays very flat, carries a ton of speed and is even more durable than before if that is even possible. I was able to cover every corner with this design. I am very pleased with it and it will be going into production as soon as possible.
As for front end, I will be offering our standard front end for now but will be working on a replacement shortly. My new front end will be a direct bolt on to the existing chassis. The new AE front end will fit for those who want to run it as it is the best front end on the market right now. Hyperdrive makes mounting blocks for it so it can mount up to any car with the bolt pattern like ours. be patient as we will have one shortly.
The pod is the same as we didnt want to change it. I havent seen anything that even comes close to it and i wanted to keep it.
If you guys have any questions, please feel free to ask. Thanks for looking.
Jason Breiner
BMI Racing
Team Associated
J Concepts
protc3 is offline   Reply With Quote
Old 02-01-2010, 08:55 AM   #8342
20 SMOKE's Avatar
Trader Rating: 100 (100%+)
Originally Posted by protc3 View Post
here are some pics of the new parts. There will be a full conversion kit for a cheap price so dont be worried.
PURPLE?.I need to come by the shop i want one
Jamie W
*Team Tekin*TLR Racing*DE Racing*92 Zero Design*AKA*DDHRC*
20 SMOKE is offline   Reply With Quote
Old 02-01-2010, 09:00 AM   #8343
protc3's Avatar
Yeah, i wanted to give it some pop. I like the gun metal color but i wanted to aluminum parts to really stand out.
Jason Breiner
BMI Racing
Team Associated
J Concepts
Old 02-01-2010, 09:08 AM   #8344
WIITA's Avatar
Trader Rating: 41 (100%+)
Car looks sweet Jason
Team CRC / Sanwa / Team scream / Genesis RC / Hobbywing / TQ Wire / Schelle / MIP / RC^2 / TEKNO / BoomRC
WIITA is offline   Reply With Quote
Old 02-01-2010, 09:16 AM   #8345
Purple brings up thoughts of horrible parts support in the past from Trinity.. What about yellow, Jason? I anodized a T4 and L4 for a guy in fluorescent yellow and it looked awesome against the black plastic/carbon fiber. Afaik NOBODY has produced a pancar in yellow (yet).
For those wanting to run the R5 front end on a chassis drilled for the old front end, here's a link to the mounts that Jason is talking about-
http://www.lefthander-rc.com/catalog...oducts_id=1929
Serzoni is offline   Reply With Quote
Old 02-01-2010, 09:25 AM   #8346
Trader Rating: 36 (100%+)
I personally think the gun metal color is awesome. Gives the car a stealth, clean look.
Please no purple! Ughh!!
EVILGRAFX is offline   Reply With Quote
Old 02-01-2010, 09:51 AM   #8347
Moderator
Clegg's Avatar
Looking forward to seeing the new ride for sale Any word on an conversion kit? (although every peice of CF other than the upper pod brace is different, so I am not sure what the point of a conversion would be.
Joe Kelly - JK720.net
5280 Raceway |5280raceway.com | 5280 Raceway Facebook
Clegg is offline   Reply With Quote
Old 02-01-2010, 10:08 AM   #8348
FERNANDO.G's Avatar
Good Job this weekend Butter, little more track time and prep and you would have laid it down.
ARC USA.TITAN.BLITZ. VIPER USA.HORIZON-HOBBY.JACO. AIRTRONICS. TEAM TRINITY.
TEAM DYNAMITE.
FERNANDO.G is offline   Reply With Quote
Old 02-01-2010, 10:10 AM   #8349
V12
V12's Avatar
Second that. Please stay with gun metal. No purple please!!!
Jason, do you have picture also from the DB10R? What new parts are coming there and in what way will they change the handling of the DB10R?
Meanwhile I tried the CK flexplates and I have to say they work very good for me (7.4V Lipo).
V12 is offline   Reply With Quote
Old 02-01-2010, 10:36 AM   #8350
TeamButter's Avatar
Send a message via AIM to TeamButter
Thanks Nando'!! Thanks for yor help and your suggestions. Helps to have a Mod 12th driver around when you are running out of setup ideas!!
A side note, Diego Gordinho is one to look out for...this little guy can WHEEL!!
He laid it down in TC and just missed winning his main against guys 2-3x's his age!!!!
Thanks again homie and I hope to see you guys soon!!!
Butter
Xray / BMI Racing / KO Propo / Team Epic / Parma-PSE / High Velocity Racing / TeamButter / P3 Graphics / MDI Racing
TeamButter is offline   Reply With Quote
Old 02-01-2010, 10:38 AM   #8351
TeamButter's Avatar
Originally Posted by AdrianM View Post
Awesone drive in both classes man! You have to be a wheel to run with those guys in the A's and you were there all week in both classes.
Originally Posted by InspGadgt View Post
Great job Butter! Can't wait to see these new parts
Thanks guys!! Hopefully I can do better at Vegas!!!
Old 02-01-2010, 10:46 AM   #8352
Looks like yes.
Old 02-01-2010, 10:56 AM   #8353
Uga
Uga's Avatar
Congrats on the near-podium finish!
About the new car: As I understand all the changes are done to make it better with stock motor? What about mod? I expect that by freeing up the rear for stock it would make it harder to handle with mod motor?
-=Xray XB4=-
-=Xray T4=-
-=Schumacher Cougar KF2=-
Racing in Latvia
Uga is offline   Reply With Quote
Old 02-01-2010, 10:56 AM   #8354
protc3's Avatar
I also want to take the time to thank Fernando Gordhino for his hard work at the Snowbirds. He had alot going on as he was running alot of classes but still did very well. He was in the B main of mod 1/12th. Thanks again guys
Jason Breiner
BMI Racing
Team Associated
J Concepts
Old 02-01-2010, 10:58 AM   #8355
protc3's Avatar
It did not lose forward bite. The car just rotated better with minimal resistance. There is plenty of room to increase and decrease rear traction. Overall the car was better and had a larger window for setup.
Jason Breiner
BMI Racing
Team Associated
J Concepts
NEW IN BOX BMI DB12R bigb11 R/C Items: For Sale/Trade 47 10-09-2008 05:36 PM
-BMI DB12R- joey R/C Items: For Sale/Trade 11 05-18-2008 10:25 PM
BMI DB12R wallstreet R/C Items: For Sale/Trade 17 02-15-2008 06:04 PM
BMI DB12R D-Bizzle R/C Items: For Sale/Trade 2 12-21-2007 04:48 PM
WTB BMI DB12R chris moore R/C Items: Wanted to Buy 8 06-29-2007 07:25 PM
SEO by vBSEO 3.5.0
