Old 12-21-2009, 08:43 AM   #8206
oze
Thanks.
Does this mean that flat servo is better on a large, flowing track?
oze is offline   Reply With Quote
Old 12-21-2009, 09:51 AM   #8207
-showtime-'s Avatar
Jason could answer that better than I could. I don't run any large tracks, sorry.
Greg Dobrosky
Showtime Designs
BMI - Parma - The Raceway at Beaver, PA
-showtime- is offline   Reply With Quote
Old 12-21-2009, 03:07 PM   #8208
protc3's Avatar
Running the servo flat will tame the car or mellow it out when it feels twitchy. I usually run it angled and work with setup.
Jason Breiner
BMI Racing
Team Associated
J Concepts
protc3 is offline   Reply With Quote
Old 12-22-2009, 04:20 PM   #8209
I know i am lame but with limited track time I would like to have it right before I get their...
Can someone post a picture of what they are doing for the spacers with the caster blocks and possibly the spring setup with the 1/10 scale pin that was mentioned earlier...
Thanks!
gguertin145 is offline   Reply With Quote
Old 12-22-2009, 05:52 PM   #8210
-showtime-'s Avatar
I'll post some pics of my front end tomorrow.
Greg Dobrosky
Showtime Designs
Old 12-23-2009, 08:42 AM   #8211
-showtime-'s Avatar
Here's the pics of my front end.
BMI's DB12R-2009-12-18-21.50.38low.jpg   BMI's DB12R-2009-12-18-21.50.57low.jpg   BMI's DB12R-2009-12-18-21.51.15low.jpg   BMI's DB12R-2009-12-22-19.58.23low.jpg
Greg Dobrosky
Showtime Designs
Old 12-23-2009, 08:45 AM   #8212
Regional Moderator
CarbonJoe's Avatar
Not quite what I was expecting from you...
*** The Gate - Celebrating 7 years at the same location ***
The difference between genius and stupidity is that genius has its limits. - Albert Einstein
Understeer is when you hit the wall with the front of the car and oversteer is when you hit the wall with the rear of the car
CarbonJoe is offline   Reply With Quote
Old 12-23-2009, 09:01 AM   #8213
-showtime-'s Avatar
Typical Gate guy, mind is always in the gutter....
Greg Dobrosky
Showtime Designs
Old 12-23-2009, 11:10 AM   #8214
Thanks for the pics!
Do you know how many spacers you used at the top of your kingpins?
What was the benefits you noticed switching up your front end like this? Were are you seeing the improvements?
Thanks!
Old 12-23-2009, 11:39 AM   #8215
Which rod ends did you use for the center brace and what size turn buckle did you use for the upper arm?
Old 12-23-2009, 12:14 PM   #8216
-showtime-'s Avatar
Thanks!
I think there are 6 of the gold spacers on top of each king pin. They are the long 1/10 kingpins so you need quite a few. As far as improvements, the long kingpins just help to get the preload right with the BMI linear springs since they are longer than the associated ones, they also give you more roll center adjustment. And the long arms calm the car down at the apex of the corner keeping the car from digging and scrubbing speed.
Those were some old Du-Bro ends I had laying around they just happened to work.
I had a machinist buddy of mine make those turnbuckles for me, the stock one will work but is a little short and not as stout as I liked it. You might be able to find one that will work online somewhere or maybe Jason could make them if enuff people want them. The specs are 6-40 thread x .875" overall length and are just made from aluminum.
Greg Dobrosky
Showtime Designs
Old 12-23-2009, 12:39 PM   #8217
AOD
AOD's Avatar
Ok Jason we want aluminum spacers for upper suspension arm and brace for xmas. Get on it.
AOD is offline   Reply With Quote
Old 12-23-2009, 01:41 PM   #8218
oze
I have seen cars built this way (from bottom up):
e-clip - spring - lower arm - steering block - 4 king pin shims - upper arm - 1 king pin shim - e-clip
This makes the upper arm more angled. What does this make to the car?
Old 12-23-2009, 02:06 PM   #8219
-showtime-'s Avatar
That will make the car more agressive at the apex of the corner as you will have more camber gain.
Greg Dobrosky
Showtime Designs
Old 12-24-2009, 07:39 PM   #8220
-showtime-'s Avatar
Hope everyone has a good Christmas!
Greg Dobrosky
Showtime Designs
NEW IN BOX BMI DB12R bigb11 R/C Items: For Sale/Trade 47 10-09-2008 05:36 PM
-BMI DB12R- joey R/C Items: For Sale/Trade 11 05-18-2008 10:25 PM
BMI DB12R wallstreet R/C Items: For Sale/Trade 17 02-15-2008 06:04 PM
BMI DB12R D-Bizzle R/C Items: For Sale/Trade 2 12-21-2007 04:48 PM
WTB BMI DB12R chris moore R/C Items: Wanted to Buy 8 06-29-2007 07:25 PM
SEO by vBSEO 3.5.0
