Old 11-29-2009, 01:52 PM   #8161
Trader Rating: 44 (100%+)
Hi guys, just had my first outing last night in Level4's old DB12RR. I used a set-up on here for a lipo battery that did not work that well for me, using the SMC 25c 4000mah pack. I dialed the car in throughout the qualifiers and by the main the car was very composed, very fast, yet easy to drive. Our track is a VERY small, very tight, high bite, Jack the Gripper ozite. While I'm not the best driver of the bunch it was easy to see the car was working well.
Front springs: BMI .020 Linear
Kingpin Lube: 20,000wt.
Camber: -2.0*
Toe: 0*
Upper arm mount: 5*
Caster shims: Back
Up travel: .25mm
Servo: JR Z3650 flat/forward
Ride height: 3.5mm
Width:166mm
Compound: Blackhawk Magenta
Additive: Jack
Amount: Full
Rear shock oil: 50wt.
Shock spring: Gold
Pod droop: 1mm
Front Ball stud: Tall
Tube Lube: 10,000wt.
Flex plates: Thin, forward mount
Flex pre-load: Screws in, but just off chassis
Battery: Forward
Ride height: 3.5mm
Width: 172mm
Compound: Blackhawk Yellow
Additive: Jack
Amount: Full
Parma Speed8 mounted slightly forward
LRP Sphere comp 2007 with TQ booster
Spektrum SR3100 receiver
Tekin 13.5
40 pinion/72 spur
SMC 1s 4000 mah 25C Lipo
Car just tickles past the 730g mark and balances perfectly with zero weight added.
The only downside, was that tire wear was suprisingly higher than expected.
biz77 is online now   Reply With Quote
Old 11-30-2009, 08:57 PM   #8162
-showtime-'s Avatar
My setup has evolved alot from what I ran at the Halloween race. I have the car carrying alot more corner speed now and Jason asked me to post where I'm at now. Still have a few more things to try, so I'll work on things more at the NEGS race at The Track next weekend. That will give me a good chance to see what we've gained against some good competion.
Front:
BMI .022 linear springs #4 surelube on pins
6 deg castor
5 deg blocks
Long upper arm
1.25 deg camber
servo angled in forward pos.
0 toe
Parma Double Pink tire cut to 1.60
3.5mm ride height
Rear:
New thin Carbon Flex plates, long position, no screws
50 wt in Silva shock w/ stock piston and Gold spring
Medium ball stud one hole forward from rear most pos.
#3 surelube in tubes
3.5mm ride height
1.5mm pod droop
Parma Orange tire cut to 1.70
Parma Speed 8 light body
The biggest gain that I made was lowering the front of the shock down. That change alone was worth almost 2 tenths at the Gate last week. I almost fell off the drivers stand when I heard the lap times called out, couldnt believe that small change made that much difference. Just some things for you guys to try out, seems the car is very sensitive to that adjustment with the lower weight.
As always any questions, I'll be happy to answer them.
Greg Dobrosky
Showtime Designs
BMI - Parma - The Raceway at Beaver, PA
-showtime- is offline   Reply With Quote
Old 12-01-2009, 02:53 AM   #8163
WIITA's Avatar
Trader Rating: 42 (100%+)
Front:
6 deg castor
5 deg blocks
Long upper arm
1.25 deg camber
0 toe
3.5mm ride height
Rear:
3.5mm ride height
1.5mm pod droop
Hey there showtime, thanks for the setup. I just put the cf plates on the car and I am going to give them a try this weekend. Before, the car was extremely dialed. Just a few questions for you.
1) What motor are you running with this setup
2) When you say lowering the front of the shock do you mean taking spacers out under the ball stud on the antenna mount?
3) Is the parma orange the same as the jaco prism orange? (yellow/gray)
thanks again!!
WIITA is offline   Reply With Quote
Old 12-01-2009, 07:09 AM   #8164
-showtime-'s Avatar
Hey Wiita
Running 17.5 Lipo. You are correct on lowering the front of the shock. You either need to go to a shorter ball stud or take spacers out. Yea the parma orange is the same tire on a black rim.
Good luck with the new plates, I think they will only make your car better.
Greg Dobrosky
Showtime Designs
Old 12-01-2009, 07:24 AM   #8165
mike ivy's Avatar
Trader Rating: 50 (100%+)
Hey Greg,
Your setup looks interesting Im going to try it at my local track at Horsham
Good luck with the new plates, I think they will only make your car better.[/QUOTE]
[-eXpress motorsports-] [-TQ Wire-]
1/12th Fo' Life!!! R.I.P Mike Reedy, R.I.P John Williams
[-Horsham RC-] [-Jackson RC-] [-RC Car World-] [ Black Out Free 2015 ]
mike ivy is offline   Reply With Quote
Old 12-01-2009, 08:00 AM   #8166
-showtime-'s Avatar
Yea, try it out. Interested to see what you think of it. Its still kind of a work in progress. I'll know more of how good it is after I try some more things at Mimi's next week. You going to make it down for the NEGS race?
Greg Dobrosky
Showtime Designs
Old 12-01-2009, 11:31 AM   #8167
Can someone explain what difference I might find between Parma Blackhawk Double Pinks and Blacks? Both are rated 35 shore, but the blacks are "exotic." What would this mean for traction/tire wear between the two?
Old 12-01-2009, 11:44 AM   #8168
Uga
Uga's Avatar
Actually blacks should be 40 not 35. As Parma is the same Jaco tire, this will be handy for you: http://bmiracing.com/bmiv4/index.php...d=15&Itemid=30
-=Xray XB4=-
-=Xray XB8E=-
-=Schumacher Cougar KF2=-
-=Awesomatix A800X=-
Racing in Latvia
Uga is offline   Reply With Quote
Old 12-01-2009, 11:49 AM   #8169
Not according to Parma:
http://www.shopatron.com/products/ca....22132.823.0.0
And if Jaco is still using the last two numbers in the model (for example: 2742 for Prism Black fronts) then black in a Jaco is a 42, not a 40.
Old 12-01-2009, 02:58 PM   #8170
mike ivy's Avatar
Hey Greg,
Yes I'll keep ya posted on how it works, That race at mimi's if my funding permits I may be down there.
Old 12-01-2009, 04:18 PM   #8171
xtrememadness's Avatar
Send a message via AIM to xtrememadness
Originally Posted by mike ivy View Post
Hey Greg,
are you guys really running 17.5 lipo. i thought we are running 13.5 with lipo?
CRAIG SANTRY / TAMIYA / TEAM ASSOCIATED / BROWNIES PRO AND SPORT HOBBIES / STATEN ISLAND SPEED TEAM / FUTABA / LRP / TEKIN / PROTOFORM / JACKSON RC / HORSHAM RC / EXOTEK RACING / REEDY
xtrememadness is offline   Reply With Quote
Old 12-01-2009, 06:51 PM   #8172
mike ivy's Avatar
Hey Craig,
Wasup, At horsham where all running 13.5 lipo
Old 12-02-2009, 02:52 AM   #8173
WIITA's Avatar
Hey Craig,
Hey mike, Since throwing that setup on the car that you reccomended the car has been extremely dialed. Just switched to the new cf thin plates and have yet to run them. Have you tried them yet? any setup changes? Thanks again mike!!!
Old 12-02-2009, 07:35 AM   #8174
-showtime-'s Avatar
Hey Greg,
Cool, we need more BMI's at the big races!
Yep, I wish we were running 13.5 but the NEGS rules are 17.5 or 10.5. Going to run some 10.5 soon it looks like way too much fun to miss out on. One good thing about 17.5 lipo is, tire wear is almost non existent. At the halloween race I ran the same pair of tires for 2 practice rounds and 3 qual rounds and they only wore .030". I chunked one so I put new ones on for Sunday or I would have ran the same set all weekend.
Greg Dobrosky
Showtime Designs
Old 12-02-2009, 08:09 AM   #8175
I'm thinking about racing 17.5 at Mimi's race. I've been racing with 13.5 with Mike Ivy at his track for the past couple weeks. Our BMI cars have been dailed. I will have a new sedan at the race next weekend. So not sure about running two classes. See you next week Greg.
Steve Walter
Sweep Racing USA/ Speed Passion USA/ Karens Famous Cookies (Transporter)
SRW141 is offline   Reply With Quote
NEW IN BOX BMI DB12R bigb11 R/C Items: For Sale/Trade 47 10-09-2008 04:36 PM
-BMI DB12R- joey R/C Items: For Sale/Trade 11 05-18-2008 09:25 PM
BMI DB12R wallstreet R/C Items: For Sale/Trade 17 02-15-2008 05:04 PM
BMI DB12R D-Bizzle R/C Items: For Sale/Trade 2 12-21-2007 03:48 PM
WTB BMI DB12R chris moore R/C Items: Wanted to Buy 8 06-29-2007 06:25 PM
