Old 11-19-2009, 06:25 PM   #8131
chris moore's Avatar
Trader Rating: 85 (99%+)
Jason, email and PM sent
fishnfst; 16ga wire is perfect.
Sponsered by:
CMDezigns Paint Works
https://www.facebook.com/pages/CM-Dezigns/259989190822177?ref=hl
chris moore is offline   Reply With Quote
Old 11-20-2009, 09:25 AM   #8132
V12
V12's Avatar
Originally Posted by jasonb View Post
Got similar improved centering on the 10R
We had samples to test, Wim should have them next week.
Jason
Ah OK, thanks. Will order them then.
Beside centering do the CK flexplates feel different regarding turn in or when running on bumpy tracks?
Running the new thin plates in the long position as stated above, do this compare more to the long or short position on the old (thick) flexplates?
I see there are also some thicker flexplates coming. For what purpose are these made, just for the 1/10th car?
Im not sure if I will be running my DB12RR this winter, I think my main interest currently is the DB10R. Which one of the new flexplates makes more sense for this car, the thin or the thick one or maybe both? I had my first indoor race with the DB10R last weekend and I liked the short position with the standard thick flexplates the best. The car worked very very good.
V12 is offline   Reply With Quote
Old 11-21-2009, 07:47 AM   #8133
avs
avs's Avatar
Originally Posted by GasGod View Post
Hi all- new to the 12rr-and 1/12.I have the lipo vers.What is the difference between the long and short mounting position on the flex plates.And is there an online tuning guide for the BMI. Thanks in advance.
there are 6 stiffness steps with 2 bars and 3 mounting options each. the short position stiffens the rear suspension, and adding the tweak screws is another step stiffer.
this forum is the onling tuning guide.
avs is offline   Reply With Quote
Old 11-21-2009, 07:59 AM   #8134
GasGod's Avatar
Thanks for the reply avs.
Guess I'll ask my ?? here then.
F! Metal Militia,VTA NATION--Team SloMoFo
losi 8t,mbx5t,rc8
rc8,Kyosho rb5,SCR
ft4 MT wallet
cyclone;xxx-s;x-rayT2;crc gen xl;bmi 12rrl
GasGod is offline   Reply With Quote
Old 11-22-2009, 12:26 AM   #8135
If you hve any questions. Just PM me. I'll do my best to help you.
Steve Walter
Sweep Racing USA/ Speed Passion USA/ Karens Famous Cookies (Transporter)
SRW141 is offline   Reply With Quote
Old 11-22-2009, 05:14 AM   #8136
avs
avs's Avatar
i guess i was a little glib. what i should have said was:
i think you will get good tuning advice from your questions posted on this thread.
Tony Shimko
Old 11-22-2009, 11:13 AM   #8137
To be more specific:
Thin flex plates
- Long position, short position, long position with tweak screws, and short position with tweak screws.
Thick flex plates
Old 11-22-2009, 05:26 PM   #8138
H I
H I's Avatar
Trader Rating: 18 (100%+)
Weve just finished our on-road National here in Australia and 2 BMI made A-main.
We got 4th and 9th place. My DB12RR felt great but got into heated battle with others and I pushed it bit too hard in early stage of finals and battery dumped in the end.
Ill try new carbon flex plate for next big meet. Is thin carbon flex plate stiffer than fibre glass thin flex plate?
H I is offline   Reply With Quote
Old 11-23-2009, 10:42 PM   #8139
awrite can't wait for my new CF flexplates to arrive.. Anyone have any use for the old g10 ones?? I have like 4 sets of new thin g10 flexplates..
fishnfst is offline   Reply With Quote
Old 11-24-2009, 12:03 AM   #8140
Old 11-24-2009, 07:03 AM   #8141
JonesyCGY's Avatar
I'm taking the plunge into the Brushless world and looking at getting the Tekin RS ESC and just wondering about a few things.
1. Whats a good length is for the Sensor Wire. Its for the DB12RR. I'll probably be buying an aftermarket wire harness but there are lots of different lengths.
2. Are there any Lipos that don't fit into the chassis slots for the lipo version DB12RR? Any reccommended Lipos?
JonesyCGY is offline   Reply With Quote
Old 11-24-2009, 07:50 AM   #8142
c-lyon's Avatar
Jonesy, I think HyperMike and some others have that Tekin.
c-lyon is offline   Reply With Quote
Old 11-24-2009, 08:08 AM   #8143
axle182's Avatar
Send a message via MSN to axle182
Jonesy, i recommend the SMC 4900mah 1s. PM me if you need one, and the sensor wire would be about a 6" wire. I think i have a spare if you want to try it first.
I found a rare blue ano 12r online, im going to convert to a RR, but obviously i think that rear bar across the pod will be a different length.... Ill maybe shim it with blue shims! Anyone know if its the same length as the R version? Cheers
Aaron "AJ" Freind
axle182 is offline   Reply With Quote
Old 11-24-2009, 08:33 AM   #8144
c-lyon's Avatar
AJ the 1/12RR measures 6cm, and that on the original 1/10 is about 5.75cm which I assume is the same as on the 1/12R.
Old 11-24-2009, 09:13 AM   #8145
JonesyCGY's Avatar
Ok Thanks guys, AJ I'll take you up on the Offer to see if the SMC fits. Hopefully gonna make it this Friday to Carcar.
NEW IN BOX BMI DB12R bigb11 R/C Items: For Sale/Trade 47 10-09-2008 04:36 PM
-BMI DB12R- joey R/C Items: For Sale/Trade 11 05-18-2008 09:25 PM
BMI DB12R wallstreet R/C Items: For Sale/Trade 17 02-15-2008 05:04 PM
BMI DB12R D-Bizzle R/C Items: For Sale/Trade 2 12-21-2007 03:48 PM
WTB BMI DB12R chris moore R/C Items: Wanted to Buy 8 06-29-2007 06:25 PM
