Old 11-18-2009, 03:10 PM   #8116
WIITA's Avatar
Trader Rating: 41 (100%+)
Hey there Jason, I'm sure you have been asked this question but I am just courious about one thing. I have my 1/12 working amazing right now with the regular rr flex plates. However, I am looking to go to the new carbon plates and really don't want the car to change on the handling end. What can I expect from these new plates as far as flex compared to the old ones? also if I am using the regular plates now will I use the regular plates when I switch? Thanks and I really appreciate the coustomer service you provide.
WIITA is offline   Reply With Quote
Old 11-18-2009, 03:39 PM   #8117
protc3's Avatar
The new flex plates will make the car trasition quicker and also hold sweepers better. We find them to have out performed the G10 flex plates in all conditions. The thin ones have become the new standard flex plate and the thick will now be the optional one.
Jason Breiner
BMI Racing
Team Associated
J Concepts
protc3 is offline   Reply With Quote
Old 11-18-2009, 04:06 PM   #8118
So is their performance similar to the thin ones or thick ones? I went back to the thick L plates on my car because it leveled out the pod better and the car handles as well with them as it does with the thin ones on my track.
InspGadgt is online now   Reply With Quote
Old 11-18-2009, 04:44 PM   #8119
Swampracer's Avatar
Trader Rating: 67 (99%+)
Default Check your e-mail
Hi Jason, please check your e-mail...I have a question about the new carbon flex-plates.
Thanks Greg G
Swampracer is offline   Reply With Quote
Old 11-18-2009, 04:50 PM   #8120
Jason, will the new RR and lipo update kits include the carbon flex plates, or the G10?
Serzoni is offline   Reply With Quote
Old 11-18-2009, 04:54 PM   #8121
WIITA's Avatar
Great. So I will just pick up a set of each and use the thin plates in place of the regular ones I am using now. Are you and your guys using the set screws with the thin plates or just using the long holes? Thanks again.
Old 11-18-2009, 07:20 PM   #8122
-showtime-'s Avatar
I'm running mine in the long position with no screws.
As far as your what to expect with the new plates, If your car was good with the thick G10 plates it will be better with the new thin ones. I think the car is just more precise with the carbon plates.
Greg Dobrosky
Showtime Designs
BMI - Parma - The Raceway at Beaver, PA
-showtime- is offline   Reply With Quote
Old 11-19-2009, 04:23 AM   #8123
GasGod's Avatar
Hi all- new to the 12rr-and 1/12.I have the lipo vers.What is the difference between the long and short mounting position on the flex plates.And is there an online tuning guide for the BMI. Thanks in advance.
F! Metal Militia,VTA NATION--Team SloMoFo
losi 8t,mbx5t,rc8
rc8,Kyosho rb5,SCR
ft4 MT wallet
cyclone;xxx-s;x-rayT2;crc gen xl;bmi 12rrl
GasGod is offline   Reply With Quote
Old 11-19-2009, 09:05 AM   #8124
WIITA's Avatar
Awesome. Thanks for the input. Cant wait to get these babys on the the car. Anyone running mod with the new plates? Which ones you using? using the screws? Thanks!!
Old 11-19-2009, 01:31 PM   #8125
We've been testing in the UK for some time - when I say testing, it took us one run to know they were better, and they've been on the car ever since!!
The problem we highlighted was that the car doesn't centre well off the turn. It tended to hold a line, meaning you had to stay out of the throttle for longer waiting for it to straighten up. Clue came when I put some springs (AE 0.020") under the flex plates (by locating them using the tweak screws) and tried that - instant traction, and easy to apply the throttle early. The springs helped to return the pod to centre faster and more accurately. I then made some carbon plates, but screwed up on the thickness! Jason, as usual, came to our rescue.
The thin CF flex plates work well in Mod and 10.5. No tweak screws needed. We run them in the long position (I run an R drilled for RR flex plates and with the shock set back 6mm, and team-mate Jason runs an RR) and never change them. I run LiPo, Jason runs 4-cell - they work for both. Not only are these plates soft enough for traction, they return to centre more accurately.
We run GT and Duo carpet with different additive (Speedtech) to you guys, but the effect seems to be the same as Showtime has experienced - the car is just more precise.
IMHO fit the thin CF plates in the long position and use them - no need to fiddle with other settings any more. HTH
SlowerOne is offline   Reply With Quote
Old 11-19-2009, 02:22 PM   #8126
V12
V12's Avatar
Someone did try the new flexplates in the 1/10th car already?
Did you guys in the UK have just some test samples or has Wim those at the shop already?
V12 is offline   Reply With Quote
Old 11-19-2009, 03:00 PM   #8127
I've been running the front hole with the standoff's reversed. Seemed to center a little better. Maintain this mounting with the new graphite pieces or swap back?
VRacing is offline   Reply With Quote
Old 11-19-2009, 03:19 PM   #8128
Got similar improved centering on the 10R
We had samples to test, Wim should have them next week.
Jason
jasonb is offline   Reply With Quote
Old 11-19-2009, 04:38 PM   #8129
Hello all I hope I didn't make a mistake in ordering the incorrect flex plates.. Are the rr plates versus the r flexplates different? I have an R and ordered some flexplates last night..
Second question is what gauge wire should I use to wire my motor and esc?
1s lipo with trinity 17.5 duo and lrp tc spec.. I tend to use 12g in my TC's but had always used 16g with my brushed stock 1/12 scale cars.. What should I be using in my 12r?
fishnfst is offline   Reply With Quote
Old 11-19-2009, 04:46 PM   #8130
The RR plates are longer but have holes drilled for the R length as well so they will work with the R.
NEW IN BOX BMI DB12R bigb11 R/C Items: For Sale/Trade 47 10-09-2008 05:36 PM
-BMI DB12R- joey R/C Items: For Sale/Trade 11 05-18-2008 10:25 PM
BMI DB12R wallstreet R/C Items: For Sale/Trade 17 02-15-2008 06:04 PM
BMI DB12R D-Bizzle R/C Items: For Sale/Trade 2 12-21-2007 04:48 PM
WTB BMI DB12R chris moore R/C Items: Wanted to Buy 8 06-29-2007 07:25 PM
SEO by vBSEO 3.5.0
