Old 11-08-2009, 08:47 AM   #8086
Originally Posted by avs View Post
Has anybody else had a problem with reverse coning on the front tires?
(the front tire wearing faster on the outside)
in 1/8 scale, camber is usually adjusted to maintain even wear across the front tire, but i am almost maxed out on camber at 1.5 degrees already.
i would like to try less camber for more control on turn in, and solve the tire wear in some other way.
AVS - You may look at your Toe & Caster settings. A lot of Caster with Toe-In would likely wear the outside edge. If you like the balance and handling, a more frequent visit to the tire truer with a ride-height adjustment might be better than going away from a comfortable setup.
Aaron
VRacing is offline   Reply With Quote
Old 11-08-2009, 10:09 AM   #8087
Lee_123's Avatar
I just picked up a used 12rr and I don't have an allen wrench small enough for the tweak screws. What size are those puppies?
Thanks, Lee B.
Member of "The Seldom Seen R/C Racing Team"
RC10L (Pro 10, WGT), TC4, BMI DB12RR, Scalpel
Lee_123 is offline   Reply With Quote
Old 11-08-2009, 11:00 AM   #8088
Uga
Uga's Avatar
Thanks, Lee B.
It's .050'', you will need it also in a few other places..
-=Xray XB4=-
-=Xray T4=-
-=Schumacher Cougar KF2=-
Racing in Latvia
Uga is offline   Reply With Quote
Old 11-09-2009, 04:42 PM   #8089
level-4's Avatar
Trader Rating: 18 (100%+)
Send a message via AIM to level-4
i have a DB 12 RR over in the for sale section
On Road Sell Out - BMI DB12RR, Automatic Tire Truer, Tires and more
my local track stopped running on road
X6 | X60 | SC10 | Ve8
level-4 is offline   Reply With Quote
Old 11-10-2009, 06:45 AM   #8090
avs
avs's Avatar
Aaron
agreed, i am comfortable with the setup but am trying to get faster, which i think means less tire scrub and speed loss on turn-in. (13.5 1s)
i have been using 5 or 10degree blocks with 4 degrees caster and a mininum toe out. i will try 10, 6 and retrue the tires next.
avs is offline   Reply With Quote
Old 11-10-2009, 04:44 PM   #8091
gubbs3's Avatar
Does anyone run the RR in Mod on carpet?
I've put some good time into the setup and have found one that is working pretty good, but it could still be better. Anyone with a mod setup they care to share?
gubbs3 is offline   Reply With Quote
Old 11-11-2009, 03:22 AM   #8092
mike ivy's Avatar
Trader Rating: 50 (100%+)
Hey Steve,
Thanks your car was dialed to I'll see ya in a few weeks
Originally Posted by SRW141 View Post
Mr Ivy, Great run yesterday at Horsham. DB12RR was flying. It was good to see BMI finish 1 and 2 in the main.
Hope to see you up there next week.
[-eXpress motorsports-] [-TQ Wire-]
1/12th Fo' Life!!! R.I.P Mike Reedy, R.I.P John Williams
[-Horsham RC-] [-Jackson RC-] [-RC Car World-] [ Black Out Free 2015 ]
mike ivy is offline   Reply With Quote
Old 11-11-2009, 03:23 AM   #8093
mike ivy's Avatar
Hey Craig,
Hows its goin? I was using a 76 spur.
Originally Posted by xtrememadness View Post
hey ivy what spur gear are you using for 1 cell 13.5
Old 11-11-2009, 07:38 AM   #8094
Uga
Uga's Avatar
You can check some of my setups in rc-setups.com, they are for RR although it states that it's the old R version. But really copying a setup won't get you the desired result, conditions may vary, you just need a good starting point and then adjust little by little depending from the conditions.
P.S.: I also have never got the car working 100% with mod, but if the new flexplates will really have the effect that Jason promised, it should cure some problems.
-=Xray XB4=-
-=Xray T4=-
Racing in Latvia
Old 11-13-2009, 07:32 AM   #8095
Moderator
Clegg's Avatar
Jason any update on when the CF flex plates will be available? I see the other CF stuff as in stock now and I am ready to order, but want to get a couple sets of the new flex plates in the same order if possible.
Joe Kelly - JK720.net
5280 Raceway |5280raceway.com | 5280 Raceway Facebook
Clegg is offline   Reply With Quote
Old 11-14-2009, 07:56 AM   #8096
chris moore's Avatar
Trader Rating: 85 (99%+)
Hey Joe, I emailed Jason yesterday and this ws the answer:
"The new flex plates are done and have replaced the G10 plates. If you order the ones on the website, they will be the carbon fiber plates."
I ordered mine yesterday
Sponsered by:
CMDezigns Paint Works
https://www.facebook.com/pages/CM-Dezigns/259989190822177?ref=hl
chris moore is offline   Reply With Quote
Old 11-16-2009, 06:04 AM   #8097
G10 or G10R's
Steve Walter
Sweep Racing USA/ Speed Passion USA/ Karens Famous Cookies (Transporter)
SRW141 is offline   Reply With Quote
Old 11-16-2009, 06:34 AM   #8098
Moderator
Clegg's Avatar
I ordered the G10R's and just told him in the comments section that I wanted the CF plates.
Old 11-16-2009, 10:13 AM   #8099
protc3's Avatar
I will have new part #'s up for the carbon fiber flex plates today. Until then you can just order the standard ones and you will get the carbon fiber ones.
Jason Breiner
BMI Racing
Team Associated
J Concepts
protc3 is offline   Reply With Quote
Old 11-17-2009, 10:43 AM   #8100
V12
V12's Avatar
Originally Posted by Uga View Post
.... but if the new flexplates will really have the effect that Jason promised, it should cure some problems.
what does that mean? I just noticed there are new flexplates coming.
V12 is offline   Reply With Quote
NEW IN BOX BMI DB12R bigb11 R/C Items: For Sale/Trade 47 10-09-2008 04:36 PM
-BMI DB12R- joey R/C Items: For Sale/Trade 11 05-18-2008 09:25 PM
BMI DB12R wallstreet R/C Items: For Sale/Trade 17 02-15-2008 05:04 PM
BMI DB12R D-Bizzle R/C Items: For Sale/Trade 2 12-21-2007 03:48 PM
WTB BMI DB12R chris moore R/C Items: Wanted to Buy 8 06-29-2007 06:25 PM
