ETA on the new flex plates, and lower rear motor pod plate? I need to order both very soon as I have a few other things i need to get ordered and I am waiting on one big one to save on the 9$ shipping.
-Joe
For Racing: BMI DB12RR-LiPo, For Fun: HPI Blitz
RCP 1/12th Scale 2009/2010 spec - Updated Often: http://www.rctech.net/forum/5734711-post1754.html
R/C Racing is: 10% skill, 10% equipment, 20% luck, 50% bullshit and drama.
Actually... its a bit weird, seems as if every kit is out of stock at BMI, and most CF parts are out of stock...
Materials shortage? A bad sign of the times? A good sign of the times (they are flying off the shelf!), Jason whats up?
I sent a few people to your store a last week to get info and pricing for a 1/12th they wanted to order but they came up empty as everything was out of stock.
-Joe
I spoke to Jason on the phone yesterday.
Turns out Jason's supplier was out of carbon fiber cuz the carbon fiber supplier was out of some of the raw material used to make the carbon fiber cuz the carbon fiber's supplier was out of the raw materials used in making the satin finish possible. Whew.
Float like an anvil. Sting like a Q-Tip!
OK Guys I finally wrote my setup down from the Halloween Classic. Its still a work in progress as this was my first time running 1 cell and the track was extremely bumpy.
Front:
BMI .020 springs #3 surelube on pins
6 deg castor
5 deg blocks
Long upper arm
1 deg camber
servo angled in forward pos.
0 toe
Parma Magenta tire cut to 1.60
3.5mm ride height
Rear:
New Carbon Flex plates, long position, no screws
50 wt in Silva shock w/ blue spring
Corally tall ball stud in rear most pos.
#4 surelube in tubes
3.5mm ride height
1.5mm pod droop
Parma Grey tire cut to 1.70
Parma Speed 8 HD light body
I think thats about it. Car was really easy to drive and was pretty much unaffected by the bumps. If there's anything I missed let me know.
Greg Dobrosky
Showtime Designs
N.E. Grand Slam Series 17.5 Foam TC Champion
A.B. Charles Hobby Shop - eXpress Motorsports - Parma - BMI - The Raceway at Beaver, PA
I have been waiting on my supplier for carbon fiber. They had a hard time getting the film used to make the material satin finish. They said i will have my panels by wednesday so we will be back on track. Sorry for the delay. The carbon fiber flex plates material is in this order so everything will be in stock next week.
Jason Breiner
BMI Racing
www.bmiracing.com
DB12RR lipo edition cars now available
Front:
Long upper arm
Rear:
how long is a 'long upper arm'? are you adding a shim between the lower arm and caster block?
could you give a measurement for the 'tall' stud? (like top of ball to chassis surface?
Thanks for the setup info! On your shock - are you using the 2-hole or the 3-hole piston with that setup? I've been running 25wt with the blue spring/2-hole piston and that's probably a bit to light.
thanks for the info, tony
For the long arm I cut the top off of a spare caster block and used that as a shim between the lower arm and the block.
Top of ball to chassis is 1.08"
Originally Posted by VRacing
Greg,
Aaron
I just used the piston that came with the shock originally, don't remember if it's 2 or 3 hole. Ineed to get some of the option pistons that Jason made so I can play with them. 25wt sounds pretty light for the Silva shock.
Greg Dobrosky
Showtime Designs
thanks, i will try these changes next week. the bmi pistons have smaller holes, so 25 and 35 wt in the bmi 2 and 3 pistons are similiar to 55 with the silva 2hole piston
Mr Ivy, Great run yesterday at Horsham. DB12RR was flying. It was good to see BMI finish 1 and 2 in the main.
Hope to see you up there next week.
hey congrats guys! ive been busy at work and putting an engine in my fiancee car but my 1/12th is ready to go and i will be at the track shortly
CRAIG SANTRY / TEAM ASSOCIATED / BMI RACING / SPEEDZONE USA / 360 RC SPEEDWAY / LONG ISLAND RACEWAY / BROWNIES PRO AND SPORT HOBBIES / STATEN ISLAND SPEED TEAM / TEAM ORION / TEAM UPGRADE / FUTABA / LRP / TEKIN / PROLINE RACING / JACKSON RC / HORSHAM RC
hey ivy what spur gear are you using for 1 cell 13.5
Thanks again Greg. The piston in the RR kit is the BMI 2-hole. I'll move the fluid weight up the scale a ways and experiment.
