Old 10-30-2009, 01:09 PM   #8041
Uga
Uga's Avatar
Originally Posted by protc3 View Post
The new flex plates are now made from carbon fiber. They are the same finish as the chassis but the material is layed out slightly different to give us the spring rate we are looking for. They center the pod more precise and they make the car transition better. The car is also more consistant through high speed sweepers with them. We found that overall, they did show a good amount of performance gain. I should have them in stock next week. They will replace the older flex plates as they have shown to out perform them.
Have you done also some proper crashtests? Carbon flexplates sound a bit fragile, at least I know that carbon T-bars where..
-=Xray XB4=-
-=Xray T4=-
-=Schumacher Cougar KF2=-
Racing in Latvia
Uga is offline   Reply With Quote
Old 10-30-2009, 01:40 PM   #8042
protc3's Avatar
There has been no reports of breakage though the testing. Test drivers say they are very durable.
Jason Breiner
BMI Racing
Team Associated
J Concepts
protc3 is offline   Reply With Quote
Old 10-30-2009, 03:02 PM   #8043
Uga
Uga's Avatar
good! Looks like I will have a reason to make a new order sooner than I expected
-=Xray XB4=-
-=Xray T4=-
Racing in Latvia
Old 10-30-2009, 04:36 PM   #8044
PartTime's Avatar
Originally Posted by Quietman View Post
Hi
Just got a tq booster but it is the type with a switch it has a black wire from the booster to the switch then from the switch one red wire.
Is this missing a blacn wire or does it pick the negative elsewhere?
It picks up everything but positive from the rx. Leave the speedo switch off and use the one on the booster.
hth
DK
PartTime is offline   Reply With Quote
Old 10-30-2009, 04:44 PM   #8045
avs
avs's Avatar
Hi
there should be a 2nd wire that goes the negative pole (black side) of the battery while the switched red wire goes to the red positive battery pole.
a switch on the red wire is all you need, the switch acts as if you disconnected the red wire, while leaving the black wire connected.
this works just fine, in your house etc. single pole switches are the norm.
avs is offline   Reply With Quote
Old 10-30-2009, 04:46 PM   #8046
chris moore's Avatar
Trader Rating: 85 (99%+)
Cool thanks Jason, I'll look for those next week.
Sponsered by:
CMDezigns Paint Works
https://www.facebook.com/pages/CM-Dezigns/259989190822177?ref=hl
chris moore is offline   Reply With Quote
Old 10-31-2009, 08:28 AM   #8047
SpraydbySprague's Avatar
Location: Conducting aggressive board meetings at my local track
Trader Rating: 64 (100%+)
Looks like I'll be placing an order soon.
Funny these flex plates are coming out now. A friend of mine and I were discussing the possibility of carbon fiber flex plates and their possible advantages when the original DB12R came out. I'm quite sure we weren't the only ppl talkin about C/F flex plates in the country at the time. Lol!
Jason, what thickness will the new plates be available in?
How would I describe my holeshots?
Three words...
Ready... Steady... Confetti!!!! (gonna need a new one of those)
SpraydbySprague is offline   Reply With Quote
Old 10-31-2009, 03:49 PM   #8048
Trader Rating: 94 (100%+)
What is the part number for the new flexplates? can we preorder?
T.M. Tires BOCA Bearings Pemberton Race Works EAM ORCA GFRP/HD Trinity Muddslide Motorsports Independent Racing Products Fantom Gravity
koz47 is offline   Reply With Quote
Old 10-31-2009, 04:52 PM   #8049
Moderator
Clegg's Avatar
Yeh I'd like to preorder also.
Joe Kelly - JK720.net
5280 Raceway |5280raceway.com | 5280 Raceway Facebook
Clegg is offline   Reply With Quote
Old 10-31-2009, 09:45 PM   #8050
-showtime-'s Avatar
The carbon flexplates have been very durable, been running them for a little while now and took some good hits with no signs of stress at all. I really like them. They center the pod much better and don't fatigue as fast as the fiberglass.
I'm currently sitting in the b main at the Halloween Classic in 17.5 and the car is the best its ever been in the high bite. Seems that the car is even better with the lipo than it was with cells. The track is verrrrrry bumpy, is pretty bad washboards everywhere and alot of the cars are bouncing badly and getting upset by the bumps. I hardly even notice them with the BMI.
Been having some horsepower issues but I think I got that figured out and havn't gotten a clean run yet. I'm only a couple tenths off the really fast guys so I thing with a good run in the final qual in the morning I can put it in the show.
Greg Dobrosky
Showtime Designs
BMI - Parma - The Raceway at Beaver, PA
-showtime- is offline   Reply With Quote
Old 10-31-2009, 10:32 PM   #8051
Execlent, thanks for that info. It sounds like these will are going to be a nice improvement, and good luck tomorrow.
Sponsered by:
Old 11-01-2009, 07:09 AM   #8052
Default Lipo 17.5 Setup?
Greg,
Sounds like you're having a pretty good event. Hope Sunday goes well. Any chance you can give us a run down of your 17.5 Lipo Setup with the new flexplates? Any changes you've made after switching the parts over from the fiberglass plates? I realize you can't give away the store here in front of everybody, but, some insight for the club level drivers is always appreciated!
Aaron
VRacing is offline   Reply With Quote
Old 11-01-2009, 12:49 PM   #8053
Here's a question. Has anyone ever bent the right rear pod plate?
I just took my 12RR apart for it's regular cleaning and noticed the right rear pod plate is tweaked. Just ordered a new one. Hopefully I'll get it by the weekend.
Three words...
Old 11-01-2009, 01:32 PM   #8054
mike ivy's Avatar
Trader Rating: 50 (100%+)
Hey Chris,
Solution: STAY OFF THE BOARDS Lol.....
[-eXpress motorsports-] [-TQ Wire-]
1/12th Fo' Life!!! R.I.P Mike Reedy, R.I.P John Williams
[-Horsham RC-] [-Jackson RC-] [-RC Car World-] [ Black Out Free 2015 ]
mike ivy is offline   Reply With Quote
Old 11-01-2009, 01:41 PM   #8055
Yip done that and only noticed after 3 events (2 National and 1 Regional). Can you believe it was still A-mains and same speed as all the other cars. It's Aluminum, so it can bend if hit.
Caio
Corally PHI/PHI 09 TEAM DRIVER
BMI DB12RR TEAM DRIVER
TOP
LRP TC SXX, LRP SXX Ver. 2, LRP X12 Octa, Futaba 3PKS Spektrum Module, Protform.
SOUTH AFRICA :)
PHI/BMI racer is offline   Reply With Quote
NEW IN BOX BMI DB12R bigb11 R/C Items: For Sale/Trade 47 10-09-2008 04:36 PM
-BMI DB12R- joey R/C Items: For Sale/Trade 11 05-18-2008 09:25 PM
BMI DB12R wallstreet R/C Items: For Sale/Trade 17 02-15-2008 05:04 PM
BMI DB12R D-Bizzle R/C Items: For Sale/Trade 2 12-21-2007 03:48 PM
WTB BMI DB12R chris moore R/C Items: Wanted to Buy 8 06-29-2007 06:25 PM
