Old 10-26-2009, 07:45 PM   #8026
avs
avs's Avatar
Originally Posted by Clegg View Post
The changes..
Went one step lower on the forward shock mount
Harder (red) spring installed
Moved the servo to the rearward mount but still flat on the chassis. This changed weight distribution (more to the rear), and ackerman.
That was about it. That and I corner weighted the car with 4 scales and added about 8 gm of lead on the Rx side.
But the bigges thing I did to improve the car... was focus on my line more and stop being so harsh on the turn in. I also turned my DR down (at about 55% now) even when running Black fronts /Yellow rears.
I did testing wtih Magenta all around, 2x Pink F / Magenta R, Purple F/Magenta R but they all lost grip and fuzzed up toward the end. Black and Yellow were faster through the entire race.
wow, that seems a little subtle. how low is the front shock location? is it in the shortest location and just clear of battery?
last week to get more steering i went to an angled servo and inline front axles, this seems a step too far(lap times were not much lower but less consistent). so maybe the answer is a little weight back, flat servo and red spring in the softest position.
thanks for the info.
tony
avs is offline   Reply With Quote
Old 10-27-2009, 08:58 AM   #8027
c-lyon's Avatar
Jason PM. Thanks.
c-lyon is offline   Reply With Quote
Old 10-27-2009, 09:38 AM   #8028
chris moore's Avatar
Trader Rating: 85 (99%+)
Jason, any update on when those new flex plates will be avalible? Also will those fit the r car or only the rr car. I need to place an order and if those will fit my old car I'd like to order those too.
Sponsered by:
CMDezigns Paint Works
https://www.facebook.com/pages/CM-Dezigns/259989190822177?ref=hl
chris moore is offline   Reply With Quote
Old 10-27-2009, 11:12 AM   #8029
protc3's Avatar
The new flex plates will be done soon. I am just waiting on the material. They will fit both the R and the RR
Jason Breiner
BMI Racing
Team Associated
J Concepts
protc3 is offline   Reply With Quote
Old 10-27-2009, 11:38 AM   #8030
Hey,
One important thing I forgot to ask... How to gear Mod 4.0T Brushless with 1S LiPo and receiver pack. I used to gear a LRP X12 5T between 30-32 mm with 4-cell, so what should it be now?
Corally PHI/PHI 09 TEAM DRIVER
BMI DB12RR TEAM DRIVER
TOP
LRP TC SXX, LRP SXX Ver. 2, LRP X12 Octa, Futaba 3PKS Spektrum Module, Protform.
SOUTH AFRICA :)
PHI/BMI racer is offline   Reply With Quote
Old 10-28-2009, 07:50 AM   #8031
avs
avs's Avatar
my current setup for reference:
10 degree blocks with (rearmost) 6 degree castor
front width increased slightly with 2 brass shims on axles
.020 front spring w/ #3 on the kingpins
angled servo
black 42mm full sauce
1 1/2 degrees camber
0.5 toeout
3.5mm ride height
slight droop (2 shims above eyelet with fresh springs)
Rear
lipo centered in slots
std flex plates in long position w/o set screw
#3 in the tubes
Gold spring w/ 50 wt. oil in the silva shock
medium ballstud +2 brass shims on shock mount 1 step from most aft location (shock is pretty close to 2.95" free length)
yellow rear tire 45mm
1. pod droop
3.5mm ride height
172mm wide
pod level
my current ambition is to search for less scrub on corner entry and more corner speed.
last week i tried inline front axles with the above which made lap times less consistant, and went back to trailing axle.
so the current questions:
1) front tire wear, even with the camber pretty much maxed out (without cutting something) i still get a reverse coning wear pattern on the front tires. with 1/8 scale i was taught to adjust camber to get even wear across the front tires.
is this common for 1/12 scale, or is there some other adjustment i should be chasing?
2) corner speed on carpet strategy(s?)
for 1/12 stock (1s 13.5) i don't see an obvious choice between
a) short tight lines with reduced corner speed
b) straight lines and medium radius corners with some loss of corner speed
b) longer radius corners at higher corner speed.
i am still a carpet newb, but it seems that the carpet sucks so much speed off the car in a turn that i want to take a tighter line to minimize this load on the car, without resorting to too much brake on corner entry.
do fast stock cars run with wide open lines or tighter lines with minimal off throttle, or some other tactic?
thanks for the help, tony.
Old 10-28-2009, 12:59 PM   #8032
Just saw this in a different thread and thought it belonged better here
http://www.redrc.net/2009/10/bmi-rac...ando-gordinho/
Old 10-28-2009, 09:52 PM   #8033
Yokomo_Ant3's Avatar
Trader Rating: 29 (100%+)
Originally Posted by PHI/BMI racer View Post
Hey,
Start about the same. I havent measured what rollout i was running but a guy here was running 49mm rollout with a 4.5t lipo car. That was on a huge track though. So maybe around the same rollout or a bit higher.
Antoni
Antoni Caretti
Team Schumacher - Team Scorpion - Sweep Racing - Bezerk RC - Adelaide RC
Yokomo_Ant3 is offline   Reply With Quote
Old 10-29-2009, 07:08 PM   #8034
SpraydbySprague's Avatar
Location: Conducting aggressive board meetings at my local track
Trader Rating: 64 (100%+)
Jason! What's the word on them new flex plates you're workin on?
How would I describe my holeshots?
Three words...
Ready... Steady... Confetti!!!! (gonna need a new one of those)
SpraydbySprague is offline   Reply With Quote
Old 10-29-2009, 09:04 PM   #8035
Moderator
Clegg's Avatar
Yeh can you give us some insight as to what they are? I have an order for parts I want to place, but since shipping is pretty expensive through the BMI store, I want to consolidate my orders. So I would dig to know what the deal is with the new plates so I know if its something I should wait for or not.
Thx
Joe Kelly - JK720.net
5280 Raceway |5280raceway.com | 5280 Raceway Facebook
Clegg is offline   Reply With Quote
Old 10-30-2009, 05:00 AM   #8036
mike ivy's Avatar
Trader Rating: 50 (100%+)
Hey Guy's, just be a little patient on new flex plates, they'll be out soon
[-eXpress motorsports-] [-TQ Wire-]
1/12th Fo' Life!!! R.I.P Mike Reedy, R.I.P John Williams
[-Horsham RC-] [-Jackson RC-] [-RC Car World-] [ Black Out Free 2015 ]
mike ivy is offline   Reply With Quote
Old 10-30-2009, 05:08 AM   #8037
mike ivy's Avatar
Hey avs,
Try these changes in blue
Hope this helps any more questions feel free to ask
Mike
5 degree blocks both shims to the back
angled servo
0.5 toeout
3.5mm ride height
Rear
std flex plates go to the next holes back w/o set screw
#4 in the tubes
Move shock mount towards rear of the car (effect: changes the leverage of the shock on the pod free's up the rear helps the car rotate better
1. pod droop
3.5mm ride height
172mm wide
pod level
As for driving lines watch and race with the faster guys at your local track. Study there lines how the drive would be the best bet
Old 10-30-2009, 06:32 AM   #8038
protc3's Avatar
Thx
The new flex plates are now made from carbon fiber. They are the same finish as the chassis but the material is layed out slightly different to give us the spring rate we are looking for. They center the pod more precise and they make the car transition better. The car is also more consistant through high speed sweepers with them. We found that overall, they did show a good amount of performance gain. I should have them in stock next week. They will replace the older flex plates as they have shown to out perform them.
Jason Breiner
BMI Racing
Team Associated
J Concepts
Old 10-30-2009, 06:39 AM   #8039
Moderator
Clegg's Avatar
Kick ass!! eagerly waiting to place that order + new flex plates
Old 10-30-2009, 01:25 PM   #8040
Hi
Just got a tq booster but it is the type with a switch it has a black wire from the booster to the switch then from the switch one red wire.
Is this missing a blacn wire or does it pick the negative elsewhere?
Quietman is offline   Reply With Quote
NEW IN BOX BMI DB12R bigb11 R/C Items: For Sale/Trade 47 10-09-2008 05:36 PM
-BMI DB12R- joey R/C Items: For Sale/Trade 11 05-18-2008 10:25 PM
BMI DB12R wallstreet R/C Items: For Sale/Trade 17 02-15-2008 06:04 PM
BMI DB12R D-Bizzle R/C Items: For Sale/Trade 2 12-21-2007 04:48 PM
WTB BMI DB12R chris moore R/C Items: Wanted to Buy 8 06-29-2007 07:25 PM
SEO by vBSEO 3.5.0
