Old 09-05-2009, 07:54 AM   #7831
Moderator
Clegg's Avatar
Originally Posted by xtrememadness View Post
has anyone tried the associated 12r5 front end now that its available or are we still having caster issues with it.
Isnt the mounting bolt too small for our chassis? we use those big 8-32 bolts, and they use the smaller 4-40 I thought.
Joe Kelly - JK720.net
5280 Raceway |5280raceway.com | 5280 Raceway Facebook
Clegg is offline   Reply With Quote
Old 09-05-2009, 08:25 AM   #7832
PartTime's Avatar
http://www.lefthander-rc.com/catalog...oducts_id=1854
All the current front ends need attention and care when building to insure the caster is the same on both sides. I think the R5 front end is the easiest to adjust and tune out of the big 3.
DK
PartTime is offline   Reply With Quote
Old 09-05-2009, 08:50 AM   #7833
Moderator
Clegg's Avatar
DK
Thats hot!
hmm I may have to build me a R5 front end to try out. I have the CRC front end and didnt like it much, the R5 though... Hmmm Anyone have a complete parts list for what is all needed to run the R5 Front?
Old 09-05-2009, 09:35 AM   #7834
PartTime's Avatar
Thats hot!
http://www.losipartshouse.com/servle...ly-cln-/Detail
All the screws are metric but the king pin, shims and axles are standard. I have BMI alum pivot balls in mine and there way better than the stock plastic ones.You could probably build the whole front for around $50 to $60, depending on how much stuff you have on hand. The front end IS all new so old L4 upper a arm ends and spindles WONT fit. I think the axles are diffrent too but dont have an old axle on hand to check. Plastic is CHEAP !! Probly $12 in the whole front end. LOL.
The adjustability is awesome. You can shim the width two diffrenet ways and adjust roll centers easily too.
HTH
DK
Old 09-05-2009, 04:40 PM   #7835
WIITA's Avatar
Trader Rating: 42 (100%+)
DK
so this may be a dumb question but with these lower arm mounts you can use the r5 front end on the db12rr lipo car?
WIITA is offline   Reply With Quote
Old 09-05-2009, 07:13 PM   #7836
mike ivy's Avatar
Trader Rating: 50 (100%+)
Hey WIITA
Naw man, its not a dumb question, don't sweat it That part from Hyperdrive with let you use the R5 front end on all of the BMI 1/12th and 1/10 cars nimh and Lipo.
[-eXpress motorsports-] [-TQ Wire-]
1/12th Fo' Life!!! R.I.P Mike Reedy, R.I.P John Williams
[-Horsham RC-] [-Jackson RC-] [-RC Car World-] [ Black Out Free 2015 ]
mike ivy is offline   Reply With Quote
Old 09-05-2009, 07:28 PM   #7837
WIITA's Avatar
Originally Posted by mike ivy View Post
Hey WIITA
So will I still be using all of the bmi ride height spacers I have to adjust ride height?
Old 09-05-2009, 08:28 PM   #7838
xtrememadness's Avatar
Send a message via AIM to xtrememadness
thats great!! looks like we will be testing the new front end on the bmi!!! sweet!!
CRAIG SANTRY / TAMIYA / TEAM ASSOCIATED / BROWNIES PRO AND SPORT HOBBIES / STATEN ISLAND SPEED TEAM / FUTABA / LRP / TEKIN / PROTOFORM / JACKSON RC / HORSHAM RC / EXOTEK RACING / REEDY
xtrememadness is offline   Reply With Quote
Old 09-05-2009, 08:39 PM   #7839
You'll want to get new spacers from AE or Fiberlyte. The BMI spacers are made for an 8-32nd screw not a 3mm.
Old 09-05-2009, 11:51 PM   #7840
Uga
Uga's Avatar
but if you read the link carefully it says "Mounts are drilled and tapped for 8-32 screws to bolt to chassis." Only I don't know how high are the arms, if the current sizes will fit, cause the BMI spacers are supposed to replace also the plastic shims on IRS arms.. All the current sizes might be too thick for R5 front end.
-=Xray XB4=-
-=Xray XB8E=-
-=Schumacher Cougar KF2=-
-=Awesomatix A800X=-
Racing in Latvia
Uga is offline   Reply With Quote
Old 09-06-2009, 05:49 AM   #7841
Ah yes that is true...haven't been getting much sleep getting ready for IIC. However looking at the 12R5s we have running locally they seem to just use a few thin washers to get the right ride height. Given that the BMI spacers may be too tall even if the hole is right...they might work just fine too...won't know until someone tries it.
Old 09-06-2009, 06:39 AM   #7842
PartTime's Avatar
ya, you will need .5mm, 1mm and 2mm shims for ride height. Havnt needed more but I cut my tires pretty low out of the box. With a 1.60 tire i need a .5mm shim to be at ride height.
HTH
DK
Old 09-06-2009, 07:19 PM   #7843
chris moore's Avatar
Trader Rating: 87 (99%+)
Good luck to all the BMI drivers this week at IIC
Sponsered by:
CMDezigns Paint Works
https://www.facebook.com/pages/CM-Dezigns/259989190822177?ref=hl
chris moore is offline   Reply With Quote
Old 09-06-2009, 08:36 PM   #7844
Trader Rating: 14 (100%+)
Chris...Do you know if Jason went to Vegas?
+1 for good luck to all BMI drivers.
SwampDog32 is offline   Reply With Quote
Old 09-07-2009, 12:20 PM   #7845
WIITA's Avatar
HTH
DK
Will the 3-32 screw fit through the hole on the shim since they are designed for a 4-40 screw?
NEW IN BOX BMI DB12R bigb11 R/C Items: For Sale/Trade 47 10-09-2008 04:36 PM
-BMI DB12R- joey R/C Items: For Sale/Trade 11 05-18-2008 09:25 PM
BMI DB12R wallstreet R/C Items: For Sale/Trade 17 02-15-2008 05:04 PM
BMI DB12R D-Bizzle R/C Items: For Sale/Trade 2 12-21-2007 03:48 PM
WTB BMI DB12R chris moore R/C Items: Wanted to Buy 8 06-29-2007 06:25 PM
