Old 08-23-2009, 04:34 PM   #7786
Trader Rating: 14 (100%+)
Finally got to run my 12rr last night. WOW! didn't make the first qualifier(technical difficulties) and in the second qualifier I had the motor slip away from the Spur. On the third qualifier I finally got some good lap times in. Roll out wasn't close till main came around. Started 6th and ended up 4th overall.
I'm running a 88 spur with a 38 pinion and got walked. Should I change to a 72 spur? The guys at Flowood are using them. I suppose I should go with the masses. Any suggestions?
Thanks again for one fine car! Everyone loved it.
Chad
SwampDog32 is offline   Reply With Quote
Old 08-23-2009, 06:47 PM   #7787
mike ivy's Avatar
Trader Rating: 50 (100%+)
Hey SwampDog32,
If you can give me the track dimensions I might be able to help. For starters, i would go to a 76 spur. Depending on your track size go to a 48 to a 51 pinion.
Hope this helps
Mike
[-eXpress motorsports-] [-TQ Wire-]
1/12th Fo' Life!!! R.I.P Mike Reedy, R.I.P John Williams
[-Horsham RC-] [-Jackson RC-] [-RC Car World-] [ Black Out Free 2015 ]
mike ivy is offline   Reply With Quote
Old 08-23-2009, 08:30 PM   #7788
Mike. Thanks for offering to help. The track I run on is about 70x36! The one I ran on last night was 80x36! Like I said the guys up there run 72 spurs and they were rocketing by. Thanks in advance for the assistance.
Old 08-23-2009, 08:38 PM   #7789
chris moore's Avatar
Trader Rating: 85 (99%+)
Hi Chad, have you ever checked out this site?
http://www.gearchart.com/index.cfm?f...n=home.default
Great place to figure out gear ratios and rollouts. If I remember correctly you have switched to brushless so like Mike said a 76 spur is a commonly used spur size by many using brushless.
Sponsered by:
CMDezigns Paint Works
https://www.facebook.com/pages/CM-Dezigns/259989190822177?ref=hl
chris moore is offline   Reply With Quote
Old 08-23-2009, 08:47 PM   #7790
Yeah Chris I just went brushless 1s lipo. I'm using Trinity DUO 2 13.5 and Fantom 5000mah lipo. Jaco Magenta tires (uncut).
Old 08-23-2009, 08:56 PM   #7791
You are under geared for sure, I'm running a rollout thats 20+ mm higher than you are. Are you using an esc like the SPX or Tekin with turbo/boost? If so those will also have an effect on the proper rollout.
Sponsered by:
Old 08-23-2009, 09:14 PM   #7792
I figured I was... I am running a Speed passion gt 2.0 pro. Thanks for the help.
Old 08-23-2009, 10:32 PM   #7793
Np depending on the actual tire size your currently rolling out around the mid 60's, baised on a 47.75mm tire size. for 1c 13.5 you need to be around a 90mm rollout as I dont believe the SP esc has the extra boost/turbo type feature that the LRP or Tekin has.
Sponsered by:
Old 08-24-2009, 06:27 PM   #7794
My batteries and stuff came in today and the new SMC packs with the bullet connectors fit great in the new DB12RR LiPo chassis!
Got an idea...what if we had a locator plate that bolts on through the shock mount holes to keep the battery from moving forward. With that we may be able to just use the o-ring to hold the battery in.
Old 08-24-2009, 06:56 PM   #7795
On Hobby Talk there is a pic of a DB12 where the seller modded the original 4-cell locator to act as a brace to keep the lipo from moving forward. But I still perfer to tape.
Sponsered by:
Old 08-25-2009, 05:05 PM   #7796
Khador12's Avatar
Finally got the electronics put in. So here is a picture.
Xray T4 14
VBC Firebolt DM 2wd buggy
Khador12 is offline   Reply With Quote
Old 08-25-2009, 06:17 PM   #7797
hey bud what gearing are you running on your 10.5????
Leon McIntosh
PRO-LINE--XRAY--RCAmerica--FX Engines--NitroPro Fuel--Kustom R/C Graphics--Schelle Racing
******* DialedSetups.com ****** Check it out!!!!!
punkracer24 is offline   Reply With Quote
Old 08-25-2009, 09:20 PM   #7798
Damit's Avatar
Trader Rating: 21 (100%+)
Default 1/12
Originally Posted by WIITA View Post
Awesome thanks for the suggestions guys. By the way what type of front end do you have on the car? Did you have to do any mods to make it fit properly?
WIITA,
Front end is from IRS, some small amout of dremeling is required other than that, good quality front end fits and works well.
IRS front end is not better or worse than the AE style front end its just different, slightly more adjustability.
Car set up for high speed asphalt tracks in Australia, running 5.5T.
Chris
B6d 2wd / B64d 4wd - SJF01 Street Jam F1 - Tamiya Mini v2
Futaba-HW-LRP-Lunsford-Reedy/Associated
South Australian Member: AERCCC #16 and ARCR 9098
Damit is offline   Reply With Quote
Old 08-25-2009, 10:21 PM   #7799
Only the lower arm and upper hinge pins are IRS, the rest is AE. It is essentially an AE front end upgraded with IRS parts. The only part you should need to dremel on the front is the upper arm mount so that the upper arm pivots freely. This can also be done by just sanding the mount. The only modification to the lower arm should be in using an 8-32nd tap to pre-thread the screw holes.
Old 08-26-2009, 05:58 AM   #7800
radio_car_racer's Avatar
Tekin esc, RS Pro or RS installed?
radio_car_racer is offline   Reply With Quote
NEW IN BOX BMI DB12R bigb11 R/C Items: For Sale/Trade 47 10-09-2008 05:36 PM
-BMI DB12R- joey R/C Items: For Sale/Trade 11 05-18-2008 10:25 PM
BMI DB12R wallstreet R/C Items: For Sale/Trade 17 02-15-2008 06:04 PM
BMI DB12R D-Bizzle R/C Items: For Sale/Trade 2 12-21-2007 04:48 PM
WTB BMI DB12R chris moore R/C Items: Wanted to Buy 8 06-29-2007 07:25 PM
SEO by vBSEO 3.5.0
