BMI's DB12R
#7621
Just got back from the track. Yes, yellows are the ticket. Had purple in front and it was pretty amazing to be honest. I do need just a touch more up front and was thinking lilac would be the ticket. The only problem I have is the car will not hold tweak. Even with the set screws in.
Set up
10 deg block
4 deg caster (arms middle)
1 deg camber
bmi .020
7000 on kingpin
servo flat with linkage behind servo
delta shock
40wt
red spring
1mm pod droop
10,000 in tubes
Front purple cut to 1.7 (push at the end of a run)
Rear yellow cut to 1.8
3.8 ride height
.068 L-plates in short setting with and w/out screw.
Had a chance to drive a new RR today. Oh ya, smoother to drive, cleaner lines and more consistent too. Very nice !
DK
#7622
Yeah, the RR was runnin good, especially since I havent touched a radio in 3 years. I think I have the electronics set now, so it will actually accelerate, lol.
I also noticed DK's tweak and it was odd. Didn't make the car undrivable but it was noticed. Hopefully balancing it a lil more will help smooth it out.
See ya on the Track wed bud!
Tim
Tim
#7624
I sent you an email about a week ago. Did you get it? It was the link off the bmi site subject: Hi.
DK
#7625
Hello,
Which is the Lipo battery more utilized in the USA? And which is your actual election?
Regards,
Regards,
#7626
ok, was eyeballing the car. Think I found out whats wrong. you listening clegg?
I bend the stock screws and picked up a bag from AE. They have a steeper angle on the head like the crc screws witch makes them sit farther down in the chassis. Great for clearance but then you relie on the center of the hole to locate the front end instead of the countersink. You guessed it, oblonged a hole in the chassis. Was looking at the front and noticed that the wheel base is shorter on the left then the right. Yes it turns harder to the right.
I did find a losi 8-32 steel screw with an allen head (part #6262) and gona pick them up after work and try them to see if they center better. Im still gona go and rebalance everything just to make sure but when looking at the front from the top, one upper hinge pin points straight and the other is toed out. Would bet money thats the problem.
Mental note: Dont run crc or ae screws in the front !!!
DK
DK
#7627
Is it a good election to use in the chassis DB12RR the servo Ko Propo PDS-951ICS? Thanks.
Regards,
Regards,
#7628
DK
DK
AE has blue 8-32 screws that they use on the L4 and those have 82 degree heads. The gold ones from the B4 and T4 are 100 degree heads.
#7629
For you guys having issues with the frontend screws has anyone tried these?
http://www.fastener-express.com/inde...D&ProdID=41113
#7630
Moderator
DK
DK
I ordered a couple sets from BMI last week just to make sure I had the right screws in hand No more head angle issues!
Also I talked to Lunsford, their 8-32 Ti screws are 90 Deg heads. Jason you said the chassis is counter sunk to 82deg? I am fine keeping to the Alloy screws and just plan to keep a bunch on hand incase I warp one in a hit with the lower IRS arms.
#7631
Moderator
Really only SMC 4000/25C is out in the market in any quantities here so far. In the next month that will change though. Lots of new packs coming out! my SMC 4000 is about to become a practice pack.
#7632
Moderator
The push you get from the purple, is it because they gum up and pick up fuz? On the ozite I run on which has turned pretty high bite, I cant run Purple or Lilac even because by the end of the run the tires are balls of carpet and have no traction on the front.
Thats the reason we are all running black fronts now. They push a bit more overall but the traction curve is very flat... Purple we had issues with the car almost traction rolling from insane front grip, then by the end of the 8 minutes barely being able to make a corner due to the fuzz build up.
#7634
haha Sucks for your chassis, but I am glad I am not the only one who had this happen. The car turned awesome in one direction and the other it would just lurch through corners. But good thing you found out about that now instead of fighting more and more with it. Maybe time to order the LiPo RR chassis?
I am working on some sources for stronger screws. The chassis is countersunk at 82 degrees. I will have more info shortly on this guys. Also will be getting 4-40x1/4 aluminum screws for the low impact areas
