Old 07-11-2009, 01:00 PM   #7591
protc3's Avatar
Nice looking buddy.
Jason Breiner
BMI Racing
Team Associated
J Concepts
protc3 is offline   Reply With Quote
Old 07-11-2009, 01:52 PM   #7592
PartTime's Avatar
Just tried the Black/pink combo. Very nice ! Smooth, consistent and it settled the car down a touch. I was running a .6 sec spread in lap times for my 6 min tests. I CAN DRIVE IT NOW !!!
Still have a few small issues and have an idea on how to fix them but wont know for sure till wed?
The car still has some weird double steering thing going on. I have a 5deg block with 2deg caster. The car will initiate a turn in spades, so much in fact that its ripping the rear lose, but then its got a slight push that sometimes it comes back and sometimes it wont. Gonna go to 10deg block and 4deg caster to see if it will even that out a little. Also gona up the tubes from 7k to 10k and thick plates. The thins wont hold tweak for too long for some reason.
We have a new layout. Its smooth and flowing so it shows any imperfections in your setup. Witch I like but the only problem I have that i would consider major is the traction roll at the end of the straight. Yes, no line, black fronts and traction rolls for the first 3 or 4 laps !! Im at 3.5mm ride height but the front tires are pretty tall at 1.7. Gona cut them down some and hope it fix's it up. Any ideas?
DK
Edit: Just checked and Im wearing off .010 inch off the front and rear a run. Nice even tire wear. Love it !
PartTime is offline   Reply With Quote
Old 07-11-2009, 02:42 PM   #7593
Iīm very new with this car, but in the Carpet Knife, the front bar strut work nice in this situations, and 30000wt in tubes help with double steering, but is possible the rear tyre lift in tight corners.
I refer to CK, because my last car Gen-X, are very diferent in front.
Greetings, Luis C.
## NOSRAM ## YOKOMO BD5W ## BMI DB12RR+ ##
luic is offline   Reply With Quote
Old 07-11-2009, 02:45 PM   #7594
To Khador12
Hello, Can you say me the dimensions of the Fantom battery? Have this battery Sub-C bulges? In the website there isnīt this information.
With this battery, Did you made any modifications in the chasis? Thanks.
Regards,
ysyracing is offline   Reply With Quote
Old 07-11-2009, 03:09 PM   #7595
Hello, the difference of dimensions of the 3,7v batteries, between the USA manufacturers like SMC, Fantom... and other manufacturers like LRP, Nosram, Intellect, GM, Hyperion, TrakPower..., is that SMC and Fantom have created the lipo battery to use in a 4 elements chasis. The other manufacturers have created the lipo battery to use in a 3 elements chasis.
I detail the dimension of a LRP-Nosram and SMC battery.
SMC, LRP-Nosram
Lenght: 92,00 mm. 69,00 mm.
Width: 45,75 mm. 47,00 mm.
Height: 20,00 mm. 23,50 mm.
Weight: 120,00 g. 140,00 g.
Regards,
Old 07-11-2009, 04:50 PM   #7596
mike ivy's Avatar
Trader Rating: 50 (100%+)
Hello There Part Time,
Maybe I can help. Im not sure what your running I would be easy if you could post your whole setup. Lol... But try this,Car's Dialed with this!!!!
Front:
Jaco prism Purples 1.65mm outer edges glued with ca (Helps eliminate traction rolling. You could go to a softer tire and do this as well)
10 Caster Block 1.5 degree camber
0.5 degree toe = (1/2 degree)
4mm ride height
.20" BMI linear spring
IRS #3 shure lube on King pins
Angled servo
Center Shock
55 or 60 wt Associated oil
IRS #4 shure lube in Dampner tubes
2mm shim under shock ball stud
Batteries center (helps with on power steering)
Thick Flex plates .70" ish
Rear Jaco prism yellows 1.75"
1.72mm rear width
4mm ride height
Proform speed 12
Also when you true your tires on the fronts, make sure the edges are slightly rounded that should help stabilize the front.
If you dont like the Jaco's yellow/purple combo try it with your tire setup up see how it works.If you CA the outer fronts you can actually go to a Liac / yellow compund you'll be dialed with this!!!
Hope this helps
Mike
DK
[-eXpress motorsports-] [-TQ Wire-]
1/12th Fo' Life!!! R.I.P Mike Reedy, R.I.P John Williams
[-Horsham RC-] [-Jackson RC-] [-RC Car World-] [ Black Out Free 2015 ]
mike ivy is offline   Reply With Quote
Old 07-11-2009, 05:19 PM   #7597
protc3's Avatar
DK
Sounds like you need to go to the short mounting on the flex plates. Traction rolling is probably coming from the rear and not the front. Too much rear bite can do that. Also go to 4 or 6 degrees of caster and about 1-1.5 degrees of camber.
Jason Breiner
BMI Racing
Team Associated
J Concepts
Old 07-11-2009, 05:51 PM   #7598
losithrasher's Avatar
hey jason, what do i need to get to turn a db12r in to a lipo rr?
thanks
josh
ONE THINGS FOR SURE ABOUT THE STINGER, NOTHINGS FOR SURE!
losithrasher is offline   Reply With Quote
Old 07-11-2009, 05:56 PM   #7599
CREWMAN's Avatar
Trader Rating: 19 (100%+)
thanks
josh
I have basically the same question but i have the db12rr. do all i need is the lipo chassis to make it the lipo car?
D&K HOBBIES!!!!
Losi 8ight-T 2.0 Race Roller/Losi 350/JR 9100 Servos/Spektrum DX3R
BMI Copperhead 12/Thunder Power Lipo/Futaba Servo/Express 17.5/Spektrum DX3R
CREWMAN is offline   Reply With Quote
Old 07-11-2009, 06:11 PM   #7600
PartTime's Avatar
thanks
josh
Lipo conversion kit
Silva bladder shock
Lowered rear pods
My car is the old car also.
Mike and Jason. Thanks for the info. Looks like I was heading in the right direction.
DK
Old 07-11-2009, 06:22 PM   #7601
protc3's Avatar
We sell the DB12RR conversion and you can get it in lipo or 4 cell. So all you would need is the conversion with the lipo option. Its $99.99
Jason Breiner
BMI Racing
Team Associated
J Concepts
Old 07-11-2009, 06:25 PM   #7602
CREWMAN's Avatar
i already have the db12rr 4 cell car though. To make it a lipo all i need is the lipo chassis plate itself right?
D&K HOBBIES!!!!
Old 07-11-2009, 07:10 PM   #7603
PartTime's Avatar
Yes, if your car is the RR then all you need is the chassis as far as I know.
DK
Old 07-11-2009, 07:14 PM   #7604
CarlosG.'s Avatar
Send a message via Yahoo to CarlosG.
Gadget, it was nice meeting you and your father.
CarlosG. is offline   Reply With Quote
Old 07-11-2009, 07:53 PM   #7605
protc3's Avatar
That is correct.
Jason Breiner
BMI Racing
Team Associated
J Concepts
NEW IN BOX BMI DB12R bigb11 R/C Items: For Sale/Trade 47 10-09-2008 04:36 PM
-BMI DB12R- joey R/C Items: For Sale/Trade 11 05-18-2008 09:25 PM
BMI DB12R wallstreet R/C Items: For Sale/Trade 17 02-15-2008 05:04 PM
BMI DB12R D-Bizzle R/C Items: For Sale/Trade 2 12-21-2007 03:48 PM
WTB BMI DB12R chris moore R/C Items: Wanted to Buy 8 06-29-2007 06:25 PM
